gredneck SatelliteGuys Pro Original poster Dec 25, 2003 154 0 Oct 13, 2004 #1 I have an old DIRECPC dish w/lnb, does anyone know if I can use that to get 121? thanks
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 4,423 18,221 Mankato, MN Oct 13, 2004 #2 yes it would work (maybe) as long as your Dish500 is Legacy equipment, you should be OK
J jlhugh Supporting Founder Supporting Founder Nov 25, 2003 866 0 Austin, Texas, United States Oct 13, 2004 #3 Don't you need to rotate the LNB like 180 degrees to get it to work?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 4,423 18,221 Mankato, MN Oct 13, 2004 #4 for directPC...no They work just like a Primestar setup
gredneck SatelliteGuys Pro Original poster Dec 25, 2003 154 0 Oct 13, 2004 #5 thanks I'll give it a try
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 4,423 18,221 Mankato, MN Oct 14, 2004 #6 does the DirectPC have 2 outputs or one?
gredneck SatelliteGuys Pro Original poster Dec 25, 2003 154 0 Oct 14, 2004 #7 I believe its only one.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 4,423 18,221 Mankato, MN Oct 14, 2004 #8 then you'd be all set
gredneck SatelliteGuys Pro Original poster Dec 25, 2003 154 0 Oct 14, 2004 #9 cool probably try it out this weekend
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 4,423 18,221 Mankato, MN Oct 14, 2004 #10 all you have to do is after you aim it, plug that output into "2" of the SW21 and the Dish500 to "1" and run check switch
L larrystotler SatelliteGuys Pro Jun 5, 2004 591 0 Winchester, VA Oct 14, 2004 #11 The 1 output LNB will only allow you to run 1 receiver with it.
