Surround Sound Forgotten?
brokenarrow
Jan 11, 2009
9
St. Francisville, LA
Hi,
So I've got this brand new HD 52" Sony Bravia and a brand new Sony Blu-Ray player and a brand new HD receiver from D*TV...
...and can't figure out how to hook up surround sound to it. The choice of audio outputs include the hdmi cable or (R) & (L) RCA jacks. The end. No other choice.
What gives? Can anybody advise me on this?
jayn_j
Press On Regardless
11,336
4,898
Sheboygan, WI
Most likely, the Sony Bravia is not surround, but is stereo only. You would connect with HDMI from the DTV receiver and the BluRay player for the cleanest connections.
The Sony may have an "ambience" mode that gives some feeling of depth, but it is not true surround. To make that work, you need to add either a home theater in a box or a surround receiver and speakers. There is a fair amount of discussion on this topic in the home theater forum (receivers and speakers)
jayn_j
Press On Regardless
11,336
4,898
Sheboygan, WI
Personally, I route HDMI through my receiver which then decodes the audio. I do all video and audio switching through the receiver.
Older receivers likely have an optical digital input (TOSLINK) and you should also have this connection on the BluRay and DTV receiver. You can route these in to a receiver as well to decode Dolby Digital surround signals.
chadzx11
1,190
memphis
I don't understand why you would run "surround sound" through a TV in the first place. To me, "surround sound" goes to a processor/reciever. TV speakers suck and can never measure up to a proper system.
Kevinw
Just a regular guy
3,002
14
Jacksonville, FL
give him a break :) Not everyone is tech savy. Lets try to help our new member out.
brokenarrow
Jan 11, 2009
9
You're correct. Thank You. However, until the next post by KevinW, I only knew of one receiver, which D*TV provides to "receive" and convert satellite signal to TV signal.
Do you have an A/V receiver?
As a matter of fact, No, and didn't know there was such a thing. I've now searched and viewed a number of these online. Just my opinion but the function of this A/V receiver should have been part of some of the other stuff I already bought. I feel gigged again by the electronics mfrs. Another part I didn't know I needed. Thank you so much for seeing my ignorance and asking the question that may have not been so obvious to some.
Well, I wouldn't, and don't know where you got that idea. Even so, I appreciate you taking the time to respond.
Thanks All.
Kevinw
Just a regular guy
3,002
14
Jacksonville, FL
Well lets get you on the right track. Depending upon budget you can get anything from a Home theater in a box (HTIB) which includes a audio receiver, what we use to call a stereo;), 5/7 speakers and a subwoofer to a seperate system bought in pieces. So let us know your budget.
Beginners guide to home theater receivers - by Erik Van Tongerloo - Helium
Search amazon for a lot of information. I will say, stay away from Bose all in one systems, Sony Dream machines or any HTIB that is all in one.
If you need cables go to HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!
As you have questions come back and ask for recommendations and suggestions
jayn_j
Press On Regardless
11,336
4,898
Sheboygan, WI
Hi Brokenarrow. I apologize for not being clear on receiver. I sometimes forget that the terms can be confused. I was trying to be gentle, and apologize for some of the others' responses. We try to be more supportive to people trying to understand this stuff. It isn't trivial. Oh, and thanks to Kevin for clarifying.
There is a recent innovation you might want to consider as well. They have recently introduced something called a soundbar. It is a single long and skinny unit designed to be mounted below your flat panel TV. It provides a "kind of" surround effect by bouncing the surround signals off the side walls of the room. It is not true surround, but it is a lot better than your TV speakers. The main advantage is that connections are very simple. You just plug the HDMI from your DTV receiver and BD player into the inputs, and the HDMI output into your TV and you are set to go.
If you decide to go the full receiver route, I would suggest going with an A/V receiver and a matched speaker set, rather than the HTIB route. I have purchased several HTIB sets in years past, and I find that they go obsolete quickly. In addition, they never have enough input connections to handle the next new thing. Take a look at the threads here. There is a wide range of solutions for both receivers and speaker sets. Members here tend to like the Onkyo 60X and 80X series, and the Denon mid range receivers. A lot of members initially buy Polk speaker sets, but Infinity and Klipsch are also well regarded. You will eventually want to add a subwoofer, but that can wait at first. Take a look around this forum for discussions on a lot of this equipment. You can also go over to AVForums.com Home and head over to their audio electronics area. This forum is more complete, but at times it is not for the faint of heart. People tend to have strong opinions and can be vicious defending them.
If you do decide to go the HTIB route, there are still a few things to consider. First, be wary of wireless surround speakers. It seems like a good idea, being able to eliminate the speaker wires, but a number of these units have had trouble with reliability of the wireless connection. If you are considering this sort of unit, be sure to read the reviews for the unit on Amazon. Look for a HTIB that doesn't incorporate a DVD or BluRay player. The technology is still rapidly changing, and any unit that is built in will soon be obsolete. Another issue is that you would eventually want to replace the speakers in a HTIB setup as they generally aren't very good. Often the receiver in a HTIB setup doesn't have the power to drive real speakers.
However, a HTIB will provide true surround and is a simple one stop solution. If you are the sort who buys something and doesn't need the latest and greatest, this can be a good solution. One further advantage is that speakers in HTIB setups tend to be small, so they integrate well with rooms. Most HTIB setups also come with the subwoofer.
Good luck with this. Feel free to ask on anything we can help with, and be sure to let us know what you decide.
brokenarrow
Jan 11, 2009
9
Wow! What a tail spin I'm in, learning this surround sound business. I had a dvd player/vhs vcr with 5.1 output and "thought" I had THE deal. Upgrading is proving to be quite educational. Thank you, KevinW and JayN_J! You've both provided me with AWSOME feedback. Thank you , but no need to be so apologetic for misreading my ignorance. Yes, I was giving the evil eye to those tiny little speakers shown for a Sony HTIB I was looking at. I'm sure they do a wonderful job for their size, even so...
Thanks for the tip on reading the reviews too. That's what I've been reading for the past few hours.
Oh, my budget? It's a little bit flexible but I'm really hoping to get it done for < $500.
Meanwhile, FedEx just delivered the HD (satellite) receiver for the bedroom. I put a Sony Bravia 32" 720p in there. :D
jayn_j
Press On Regardless
11,336
4,898
Sheboygan, WI
Be careful with the Sony HTIB setups. Many of them have NO inputs other than the built in DVD and an optical input from the TV. You need at least 2 HDMI inputs. Three would be better. There is one other thing you need to be aware of. A lot of the lower end systems simply supply HDMI video passthrough and do not do audio decoding. In order to get sound to your receiver, you need to make an additional optical digital audio connection (TOSLINK)
I assume you were looking at the BDVIS1000. BTW, those tiny Sony speakers are surprisingly good as long as you use the bundled subwoofer. As for the ability to decode HDMI audio, there are two conflicting pieces of information. First, the product description says New HDMI repeater (2in/1out) It also says it handles Dolby TrueHD and dts-HD. Those are only passed through HDMI and not over TOSLINK. However, they could also be decoded only by the internal BD player only, and not on external devices. I don't see this as a serious drawback, as long as you use the internal BD player. Most content from the DTV box won't use advanced audio CODECs, althougfh this may change in the future. The worst that would happen is that you would be limited to DD or DTS and that's a big improvement over what you have now. The biggest thing that worries me is that 3 of the 8 people who wrote a review talked about not being able to connect the wireless rears. If you get this, look at the review that mentions the P/N of the "booster" cable and be prepared to ask for it.
Kevinw
Just a regular guy
3,002
14
Jacksonville, FL
[ame=http://www.amazon.com/Onkyo-HT-S5100-Channel-Entertainment-System/dp/B0016KAU3U/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1232043745&sr=8-1]Amazon.com: Onkyo HT-S5100 7.1 Channel Home Entertainment System (Set of Nine, Black): Electronics[/ame]
[ame=http://www.amazon.com/Samsung-HT-AS720ST-Blu-Ray-Matching-Channel-Theater/dp/B000YO8H5C/ref=sr_1_2?ie=UTF8&s=electronics&qid=1232043893&sr=8-2]Amazon.com: Samsung HT-AS720ST Blu-Ray-Matching 5.1 Channel Home Theater System (Set of Seven, Black): Electronics[/ame]
or this
[ame=http://www.amazon.com/Onkyo-TX-SR605-Channel-Theater-Receiver/dp/B000OBLARC/ref=sr_1_1?ie=UTF8&s=electronics&qid=1232044036&sr=1-1]Amazon.com: Onkyo TX-SR605 7.1 Channel Home Theater Receiver (Black): Electronics[/ame]
with this
[ame=http://www.amazon.com/Polk-Audio-Channel-Theater-Speaker/dp/B0002WTK4S/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1232044109&sr=8-1]Amazon.com: Polk Audio RM6750 5.1 Channel Home Theater Speaker System (Set of Six, Black): Electronics[/ame]
jayn_j
Press On Regardless
11,336
4,898
Sheboygan, WI
Good suggestions. I would recommend going with the Onkyo 606, rather than the 605, even though it adds $100
[ame=http://www.amazon.com/Onkyo-TX-SR606-Channel-Theater-Receiver/dp/B0015S8PGW/ref=dp_ob_title_ce#]Amazon.com: Onkyo TX-SR606 7.1 Channel Home Theater Receiver (Black): Electronics[/ame]
The reason is that it has 4 HDMI inputs, rather than 2 and that can be a big deal. BTW, I own a 605 in my main system.
FWIW, the Onkyo 6100 and 7100 HTIB systems simply add speakers to a 606. The comments that come through in the reviews would seem to indicate you would be better off using the speakers Kevin suggests.
Note that the 5100 system only has HDMI passthrough and uses the lesser 506 receiver. The 6100 uses the 606 receiver, but adds $200 and goes over budget.
[ame=http://www.amazon.com/Onkyo-HT-S6100-Channel-Receiver-Speaker/dp/B001AMY7ZQ/ref=sr_1_15?ie=UTF8&s=electronics&qid=1232045586&sr=1-15]Amazon.com: Onkyo HT-S6100 7.1 Channel Receiver and Speaker Package: Electronics[/ame]
There are a couple of Denon HTIB systems out there, but the lower end one (589BA $499) doesn't do audio decoding over HDMI [ame=http://www.amazon.com/Denon-DHT-589BA-5-1-Channel-Theater-System/dp/B001CSEZY6/ref=sr_1_9?ie=UTF8&s=electronics&qid=1232045834&sr=1-9]Amazon.com: Denon DHT-589BA 5.1-Channel Home Theater System: Electronics[/ame] and the 789 busts the budget at $899
BTW, I would look at any of these over the available Sony systems. Better bang for the buck.
brokenarrow
Jan 11, 2009
9
Ok, I know... I got off topic for a sec with the wide eyes over the cheap hdmi cables, but you have to understand, apparently the TV guys seen idiot on my face when I walked in and managed to sell me a hdmi cable( a good one, mind you), for $50.00. The thing ain't made of pure gold though. They got me with that.
As far as these suggestions... You guys are top notch. Y'all are putting as much effort into my education here as the TV salesman, and you're obviously doing this just to be helpful. Kudos to you both.
Check this out. This is the back of the Onkyo 606...
This I like very much. Got more studying to do on y'all's suggestions.
Thank you very much.
jayn_j
Press On Regardless
11,336
4,898
Sheboygan, WI
It was 499 last week when Amazon was out:eek:
Everybody seems to be out of stock right now. It's been about a year since it replaced the 605. If so, you can expect this thing to go on clearance sale soon at lots of sites (ecost.com, 6ave.com, etc)
Pansat 9200HD - Playback
Sharp 108" LCD Monitor
