Swapping TVs
Cune
10
Hello. I swapped TVs and now I'm unable to get the volume up/down to work. Everything else works that I know of (changing channels, etc.).
The receiver/remote stayed together, just the TVs were switched.
Does anyone know how to get the volume to work?
Thanks!
I know its not a replacement remote, but this is the link to remote programming instructions.
http://www.dishnetwork.com/SupportSection/remote-setup
At the bottom, choose the model of your receiver and find the 3 digit codes to the type of TV you have. To program the remote:
1) Hold the white "TV" button at the top of the remote until all mode lights are lit.
2) When you let go, "TV" should be flashing
3) Press the 3 digit code
4) Press #
5) Try changing the volume, if it works, press "SAT" to put your remote back in satellite mode. If the volume does not work, repeat steps 1-4 using different codes until you get one that works.
If none of the codes work, use the powerscan option (it goes through all codes to see if any will work).
Dish Remote Question
will we ever get shows on demand?
