switch for qph 031 lnb
arbitroch
What kind of switch do i need to get both signals with my qph031 and dgiwave 7200 reciver
I use a 2 way DiSEqC switch! (A 22khz switch would also work since this is a standard LNBF)
will this switch work with a motor sg2100 i tray a 4X1 Switch and i only get one signal. and if I upplug the one cable and move it over i get the other. Or the other way around. the switch is between the dish and the motor. if that helps
Thank you
Yes it will work, I use a 2 way DiSEqC switch with my Moteck SG2100 motor. I also have my switch between the LNB and motor.
Make sure you have set up your receiver correctly. I use Port one for Linear and Port 2 for Circular under DiSEqC Switch in the Antenna Setup.
Make sure to power down (turn off) the receiver before connecting or disconnecting a DiSEqC switch as it may blow the switch!
Thank you!
For all your help. Now i have to find a supp. that has this kind of switch. the people that i got mi motor and lnb don't seem to have a two way switch on their site.
I am sure all our GOLD sponsors at the top of the page have them, good luck!
If you use 4x4, like I do, make sure you choose the correct options in the receiver. Mine has #2 as circular and #4 as H/V. I have the other two ports on the switch in the other two ports on the lnb, but #3 and #1 don't seem to pull in any signals any of the time... Also, on the circular, make sure to 11720
Mastermesh, you meant to say make sure L.O. on the circular is 11250 ;)
11720 is the PITA transponder on G-10R :D
Great local dealer in Florida
Euro birds over here??
