My Sony TV has four HDMI inputs for DVR, DVD, etc. It was quite easy to switch between them with my DirecTV remote but I can't seem to find a way to switch between these inputs with the Dish 52.0 remote. Can someone please help me?
Are you asking how to program your remote or what button to push?My Sony TV has four HDMI inputs for DVR, DVD, etc. It was quite easy to switch between them with my DirecTV remote but I can't seem to find a way to switch between these inputs with the Dish 52.0 remote. Can someone please help me?
Jon, you should be able to do that from the Remote menu. Press Menu, Stetting, Remote. Go down to the TV and press Enter. Select TV Pairing Wizard. Go down to Sony and press Enter. From there go left 2 spaces and select Find Model Number. Find your model number and select it.Sorry I missed your earlier post. I guess I would like to know the code for my TV to try inputting that. Is there a table of those somewhere?
First, let's be sure of the remote that you are using. If it is the new 52 remote you should press the TV button on the side of the remote and then the input, also on the side. Don't touch the buttons on top at all. This will work on both Hopper and Joeys.As it stands now when I press TV and then input both TV and DVR flash at the top of the remote and the receiver switches between DVR tuners as if still in SAT mode.
The installer paired the remote and I suspect he accepted the first code since VOL and MUTE do work but not the INPUT button. He obviously did not confirm the INPUT button worked.
It definitely is a 52 remote. I have three of them. If you have a 52 remote you will see SAT light up on the top of the remote when you press the button. Same with TV and AUX to confirm the mode it is in.
To change inputs press on the 52.0 do the following:
- (on the side of the remote )press TV
- (on the same side of remote) press input
The buttons are hidden and are on the side of the remote normally where an average persons thumb might rest when holding the remote on the Top Left hand side.
Current DNS Technician
Best to read before you jump in.Didn't read every post , just saw the title and OP, and covered what needed to be said.![]()
