T-5/IA-5 Help
Skarkrocks
5
I recently inhereted an FTA setup and I'm having problems picking up anything from Telstar 5/IA 5
I'm using a Winegard DS-2076 dish. Natsat 1000A receiver. LNBF is a PF7500.
My coords are: 47.6 and 117.6. I'm aiming at: 135.2 and 31.7.
I've read the list from http://www.global-cm.net/MPEGlistKuBandUS.html and I've tried using 12152 to tune it in, but I can't get any signal at all (it seems).
I've got great line of sight with the dish, no obstructions at all. I move the dish very slowly and wait for the meter to update on a small tv i have nearby, but I've never seen even a glimmer of signal.
Help, wife is ready to choke me out if I don't get FTA thai tv going :)
are you using a comapas to aim at 135 degrees? if so from the coordinates you gave you need to add 17degrees for magnetic deviation 135+17= 152 deg on a compas. Hope that helps
Using your coordinants and Sadoun's site calculator for fixed dish, I get:
Elevation = 31.8
Azimuth = 153
Skew = -17.8
Hope this help's. Good luck!
Al
OK its a Standard so make sure the L.O. is set to 10750
If your receiver has BLIND SCAN and you feel you are close to a satellite try that!
If you do find any channels let us know and we will tell you what way to move the dish from there!
I see Iceberg beat me to it :)
Yes!
Code:
         Latitude 47° 36.000'N Longitude 117° 36.000'W
                       Sat Name Sat Lng Az(t) Az(m)    El  Skew
                           IA-5   97.0W 153.0 135.3  31.7 -17.8
                              Satellite Finder is (c) Copyright 2004, P. Lutus
Make sure you have the skew set correctly, it should be clockwise (from front of dish)
http://www.sadoun.com/Sat/Installation/LNBF-Installation.htm
