TERK TV 20 power suppl voltage?
al berry
Northeast Ohio
I have a TERK TV 20 antenna that I hadn't used for a while. I moved and want to use it again.
I can't find the power supply, and cannot find any info as to the DC output voltage. I have a box full of power supplies of every description - so one might work; or one of the "universals" will fit if I know the DC votage.
I still have the original box and instructions sheet, but that does not show the output voltage. Can you help? The voltage should be marked on the power supply.
al berry
This isn't exact, but the size of the "hole" varies based on the voltage. What that means is, the "plug" ends will also vary based on the voltage so match the sizes and you should match the voltage.
I do see that antenna on eBay and the seller includes a 12v, 200ma adapter.
OTA Antenna Install
