TV2 coax only will output TV1 signal
towboy123
SatelliteGuys Guru
Nov 30, 2010
129
FSM In Raleigh
I have tried everything it is in dual mode. Shared view disabled. Set to the correct channel. If I run RCA TV2 works fine. I have even run a coax straight from TV2 out to TV2 with the result. Box has been replaced. Any help would be useful
Go to menu-6-1-5 and turn off TV1's modulator. Can you also confirm that the mode says "Dual Mode" in the system info screen? Or, if the TV2 can go to channel 73, change the modulator setup to cable
Not sure I understand your question
The receiver output is set on the Local Channels screen and can be off-air or cable, some tv's will scan what is set. If receiver is set to off-air, tv should be set to antenna. If the tv is set to cable and tv1 is on a low channel number while tv2 is on a higher channel number the tv will pick up tv1 but not tv2.
Check Switch Error
Bluetooth
