ULTRASAT RECEIVER + 33" DISH ---HELP!
piccolino
Hello
I am in Canada, my postal code is L0B 1L0.
I just bought an ultrasat receiver, 33" dish and I have a Qsat 88-1000 KU-BAND LNBF.
The ultrasat apparently has the same configurations as the Coolsat 4000. I would like to know what my receiver settings are, and which FTA satellite I should be aiming at. I would like to receive english channels if possible. Thank you in advance
Welcome to Satelliteguys :)
Try for Galaxy10R, there are quite a few English-speaking channels on that sat.
Set your receiver to either Universal or Single (Depending whether your LNB is uni or single) in LNB settings, aim your dish and scan.
PSB may be along in a few minutes with a big list of satellites you can try aiming for.
NESTLETON STATION, ON
Latitude 44° 0.000'N Longitude 79° 0.000'W
Sat Name Sat Lng Az(t) Az(m) El Skew
Intelsat 901 18.0W 111.1 123.2 11.9 -42.2
Intelsat 603 20.0W 112.7 124.8 13.3 -41.6
NSS 7 22.0W 114.3 126.5 14.6 -41.0
Intelsat 905 24.5W 116.4 128.5 16.3 -40.1
Intelsat 907 27.5W 118.9 131.1 18.3 -39.0
Hispasat 1C/1D 30.0W 121.1 133.3 20.0 -38.0
Intelsat 801 31.5W 122.5 134.6 21.0 -37.4
Intelsat 903 34.5W 125.3 137.4 22.9 -36.0
AMC 12 & Telstar 11 37.5W 128.1 140.3 24.7 -34.5
NSS 806 40.5W 131.1 143.3 26.5 -32.8
PAS 6B/3R 43.0W 133.7 145.9 27.9 -31.3
PAS 1R 45.0W 135.8 148.0 29.0 -30.1
Intelsat 705 50.0W 141.4 153.6 31.6 -26.7
Intelsat 707 53.0W 144.9 157.1 33.0 -24.4
Intelsat 805 55.5W 148.0 160.1 34.1 -22.4
PAS 9 58.0W 151.1 163.2 35.1 -20.4
Amazonas 61.0W 154.9 167.1 36.2 -17.7
EchoStar 3 & Rainbow 1 61.5W 155.6 167.8 36.3 -17.3
Estrela do Sul 1 63.0W 157.6 169.7 36.8 -15.9
Brasilsat B2 65.0W 160.3 172.4 37.4 -14.1
Brasilsat B1 70.0W 167.2 179.3 38.5 -9.2
Nahuel 1 & AMC 6 72.0W 170.0 182.1 38.8 -7.2
DirecTV 5 72.5W 170.7 182.9 38.9 -6.7
SBS 6 74.0W 172.8 185.0 39.0 -5.2
AMC 5 79.0W 180.0 192.2 39.3 0.0
Nimiq 2 82.0W 184.3 196.5 39.2 3.1
AMC 9 83.0W 185.7 197.9 39.1 4.1
Brasilsat B3 84.0W 187.2 199.3 39.0 5.2
AMC 16 85.0W 188.6 200.8 38.9 6.2
AMC 3 87.0W 191.4 203.6 38.6 8.2
Intelsat Americas 8 89.0W 194.2 206.4 38.3 10.2
Galaxy 11/Nimiq1 91.0W 197.0 209.2 37.9 12.2
Brasilsat B4 92.0W 198.4 210.6 37.6 13.1
Telstar 6 93.0W 199.7 211.9 37.4 14.1
Galaxy 3C 95.0W 202.4 214.6 36.8 15.9
Intelsat Americas 5 97.0W 205.1 217.2 36.2 17.7
Galaxy 4R 99.0W 207.7 219.8 35.5 19.5
AMC 4 101.0W 210.2 222.4 34.7 21.2
AMC 1 103.0W 212.7 224.8 33.9 22.8
AMC 15 105.0W 215.1 227.2 33.0 24.4
Anik F1 107.3W 217.8 229.9 31.9 26.1
DirecTV 6 & EchoStar 6/8 110.0W 220.9 233.0 30.6 28.1
Anik F2 111.1W 222.1 234.3 30.0 28.8
Solidaridad 2 113.0W 224.2 236.3 29.0 30.1
SatMex 5 116.8W 228.2 240.3 26.9 32.4
EchoStar 7 & DirecTV 7S 119.0W 230.4 242.5 25.6 33.6
EchoStar 9/Intelsat Americas 13 121.0W 232.3 244.5 24.4 34.7
Galaxy 10R 123.0W 234.3 246.4 23.2 35.7
Galaxy 12 125.0W 236.1 248.3 21.9 36.7
Galaxy 13/Horizons 1 127.0W 238.0 250.1 20.6 37.6
Intelsat Americas 7 129.0W 239.8 251.9 19.3 38.4
AMC 11 131.0W 241.5 253.7 18.0 39.2
Galaxy 1R 133.0W 243.2 255.4 16.7 40.0
AMC 10 135.0W 244.9 257.1 15.3 40.6
AMC 7 137.0W 246.5 258.7 14.0 41.3
AMC 8 139.0W 248.1 260.3 12.6 41.9
EchoStar 1/2 148.0W 255.1 267.2 6.3 44.0
Satellite Finder is (c) Copyright 2004, P. Lutus
piccolino said:
Hello
Cool, I just purchased an Ultrasat :) maybe you can give us a review on it once you get it going. :D
Ben
Compass
Thank you for that list.
I have a few directional questions.
For example, if i want G10
"Galaxy 10R 123.0W 234.3 246.4 23.2 35.7"
Which way should my satellite be pointing using an ordinary compass?
In other words, if i get outside on my roof , with my compass, using the example of G 10 , would it be correct to point the satellite 123' W or should I convert that somehow. IE instead of W , point the satellite 123' East.
ALSO when I am figuring out elevation, is it okay to use an angle finder at the centre of my dish instead of the stamped degrees on the hardware itself?
thanks in advance.
I would use the elevation scale on the side of the dish. (23 deg.)
246 deg (w) on the compass is your magnetic az. (on compass)
234 deg. (w) is the True az. (is the reading after taking the magnetic deviation into account)
Pentagon Channel on G10R?
T-Pod question
