Uplink Activity - 11-20-2008 12:50pm ET 19 changes
JohnH
Godfather of the Uplink Reports
Oct 5, 2003
3,013
Kansas City, Missouri
UPLINK ACTIVITY: SAMPLE TAKEN 11-20-2008 12:52:00 TO 11-20-2008 12:53:06 ET
19 CHANGE(S)
CHNG 834 PSNES MPEG2 SD Tp 19 EchoStar 11 110w UNAVAIL HIDE
TO 834 PSNES MPEG2 SD Tp 19 EchoStar 11 110w AVAIL
CHNG 5190 KATV{LITTLE ROCK, AR} MPEG4 HD Tp 9 EchoStar 8 77w UNAVAIL HIDE HD MAP 7
TO 5190 KATV{LITTLE ROCK, AR} MPEG4 HD Tp 9 EchoStar 8 77w AVAIL HIDE HD MAP 7
CHNG 5191 KTHV{LITTLE ROCK, AR} MPEG4 HD Tp 9 EchoStar 8 77w UNAVAIL HIDE HD MAP 11
TO 5191 KTHV{LITTLE ROCK, AR} MPEG4 HD Tp 9 EchoStar 8 77w AVAIL HIDE HD MAP 11
CHNG 8450 WRTV{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 6
TO 8450 WRTV{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 6
CHNG 8451 WISH{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 8
TO 8451 WISH{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 8
CHNG 8452 WTHR{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 13
TO 8452 WTHR{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 13
CHNG 8453 WXIN{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 59
TO 8453 WXIN{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 59
CHNG 8454 WTTV{BLOOMINGTON, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 4
TO 8454 WTTV{BLOOMINGTON, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 4
CHNG 8455 WNDY{MARION, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 23
TO 8455 WNDY{MARION, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 23
CHNG 8456 WFYI{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 20
TO 8456 WFYI{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 20
CHNG 8457 WHMB{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 40
TO 8457 WHMB{INDIANAPOLIS, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 40
CHNG 8462 WTIU{BLOOMINGTON, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP 30
TO 8462 WTIU{BLOOMINGTON, IN} MPEG2 SD Tp 18 Spot 13 EchoStar 10 110w AVAIL HIDE MAP2 30
CHNG 9352 KARK{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w UNAVAIL HIDE MAP 4
TO 9352 KARK{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w AVAIL HIDE MAP 4
CHNG 9353 KLRT{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w UNAVAIL HIDE MAP 16
TO 9353 KLRT{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w AVAIL HIDE MAP 16
CHNG 9354 KWBF{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w UNAVAIL HIDE MAP 42
TO 9354 KWBF{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w AVAIL HIDE MAP 42
CHNG 9355 KASN{PINE BLUFF, AR} MPEG4 SD Tp 9 EchoStar 8 77w UNAVAIL HIDE MAP 38
TO 9355 KASN{PINE BLUFF, AR} MPEG4 SD Tp 9 EchoStar 8 77w AVAIL HIDE MAP 38
CHNG 9357 KVTN{PINE BLUFF, AR} MPEG4 SD Tp 17 EchoStar 8 77w UNAVAIL HIDE MAP 25
TO 9357 KVTN{PINE BLUFF, AR} MPEG4 SD Tp 17 EchoStar 8 77w AVAIL HIDE MAP 25
CHNG 9358 KKYK{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w UNAVAIL HIDE MAP 49
TO 9358 KKYK{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w AVAIL HIDE MAP 49
CHNG 9359 KETS{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w UNAVAIL HIDE MAP 2
TO 9359 KETS{LITTLE ROCK, AR} MPEG4 SD Tp 9 EchoStar 8 77w AVAIL HIDE MAP 2
19 CHANGE(S) 5819 CHANNELS IN THE SYSTEM
digiblur
14,190
4
Louisiana
Still waiting for those Tulsa HD locals to become available.
They could be uplinked but not physically ready yet. Are you receiving any signal from that TP?
On another note... might be time for me to get rid of my 110/119/61.5 setup and go with a 1000.4 setup and check out the weather in Little Rock. Only thing is I'll have to keep a 110 for OTA guide info.
digiblur
14,190
4
Louisiana
It will be a week or two before they are available.
Thanks John H for posting the update. Don't know where the DigiNit is. :)
Someone accidentally forgot to close TSReader after moving the dish. Then I forgot to add the DigiNIT email to my text message white-list, so I never got the failure alerts.
D
DigiSAT Uplink Report
Guest
Uplink Activity Report - 11/20/2008 1:34pm - 10 changes
SatelliteGuys.US DishNetwork Uplink Activity Report - 11/20/2008 1:34pm - 10 changes
Uplink Comparison Range: 11/20/2008 11:02A - 11/20/2008 01:34P
Channel Package Flag Changes:
834 - PSNES [MPEG2 SD] - EchoStar11 110W TP 19 ConUS beam changed to Available
5190(7) - KATV [MPEG4 HD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
5191(11) - KTHV [MPEG4 HD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
9352(4) - KARK [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
9353(16) - KLRT [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
9354(42) - KWBF [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
9355(38) - KASN [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Pine Bluff, AR)
9357(25) - KVTN [MPEG4 SD] - EchoStar8 77W TP 17 ConUS beam changed to Available (H)(Pine Bluff, AR)
9358(49) - KKYK [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
9359(2) - KETS [MPEG4 SD] - EchoStar8 77W TP 09 ConUS beam changed to Available (H)(Little Rock, AR)
Channels in the system: 5819
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
cwk3
79
Arkansas (Little Rock DMA)
ok, someone please help me understand this. I've been a dish customer for about 12 years and recently got into the turbo hd and got a upgrade to superdish for 110, 119 and 129 to accommodate the new HD channels. Now they come up with local hd for little rock and the only way I can see them is on 77? This doesn't make any sense to me at all. Will they be mirrored on 110 & 129 eventually? Besides isn't the EA for west of Mississippi river? I'm totally confused and wondering what the hell is going on. Someone please help me. I've fallen and I can't get up!
osu1991
10,488
2,952
Broken Arrow, Oklahoma
Yeah I figured maybe next week, if we're lucky. Had my hopes up. It's kinda influencing whether I order 1 or 2 dtvpal dvrs, though. Being able to have those two sat tuners record hd locals would save the family some grief and i would just get 1 pal dvr.
digiblur
14,190
4
Louisiana
I take that back. I thought they had the 4 HD's. I'll pass.
digiblur
14,190
4
Louisiana
I highly doubt you'll see them duplicate the Little Rock, AR market on western arc too, but you never know what they have planned for Ciel-2.
cwk3
79
So it appears to me that they are wasting space as none of the new Turbo upgrades in Arkansas have 77 or at least in my area of central AR. Go figure! It seems to me that when I was upgraded that these issue would have been addressed. Oh well, live and learn.
Direct has already uploaded Ft. Smith HD and they are 1/2 the market that L.R. is. I wish now that I hadn't upgraded with the 2 year commitment.
D
Uplink Activity Report - 11/21/2008 6:02am - 1 change
D
Uplink Activity Report - 11/22/2008 6:02am - 1 change
