Using the Sun to get an Azimuth
penguinsix
SatelliteGuys Guru
120
Despite sleeping through much of Astronomy, I recall that the Sun is more or less "due South" at noon (quite a stretch).
Checking http://www.emphemeris.com and my Astronomy program Starry Night, I've discovered that the Sun will hit the meridian tomorrow at 12:50:44 EDT. In fact, the Sun will be at 40 degree elevation (I need 38.9).
Since there isn't much magnetic declanation with the Sun, can I basically just point the dish at the Sun at that hour to find true South? I don't seem to have a satellite exactly at my long (76.5376) but suspect one won't be that far off.
Anyone had any luck with "solar pointing" of a dish?
Actually this worked out really well. I put a couple of poles in the yard in front of the dish when the sun was directly south (Starry Night said 12:50:44). I lined them up using the shadows, and then put sticks in the ground to create a "line" that was true south. Checked it with a compass but once I had the marker down it was quite easy.
It's finally all here . . .
Signal Quality 60, can I do better?
