Hi everyone.
I am having problems getting channels to show. My signal strength shows 82%. Here is my setup and local information:
Zip Code 75034
My true south sat is T5 based on my location.
Viewsat vs2000
HH90 motor
Invacom qph-031 lnb
I only have 1 cable connected to the linear side of the lnb. This goes into the motor then to the receiver. I left the disq switch out of the loop.(do i need it to setup system?)
My antenna setup for t5 is:
lnb power on
lnb type universal
lnb high 10600
lnb low 9750
tp frq. 11749 (for the t5 sat)
search option all
diseqc 1.0 none
motor user
I have tried using the automatic channel search and also the manual search. It always fails. My signal bar on the right of the screen shows between 80-86 %. I have also tried to make a new channel using information from the lyngsat web site and putting in different channel data..
I setup my dish angles using the information on Sadouns website.
Any help would be appreciated..
Zip Code 75034
Viewsat vs2000
HH90 motor
Invacom qph-031 lnb
lnb power on
lnb type universal
lnb high 10600
lnb low 9750
search option all
diseqc 1.0 none
motor user
