VOOM STB LOCKUP? This MAY Help.........
Jahbig
38
While trying to get the caller ID function to work,...I discovered the installer
hadn't plug the phone line from the STB to the wall jack....Hmmmm....so I
did the honors and LOCKUPS galore, before this no lockups....I hard booted 3 times in five minutes. So I changed the flat phone line to the round high speed type you get in a DSL package connected it to the STB and the other end to a DSL microfilter to the wall jack and VOILA, no more lockups, and caller ID works. Solution: Connect a round high speed DSL phone cable to
the STB and connect a DSL microfilter to the other end of the cable, then
connect the microfilter to the wall jack....Happy Vooming
Were you connected without microfilter when you were getting those lockups?
I was only connected with the flat type phone cord on the STB end.....never
knew the other end wasn't connected until I decided to investigate while
the STB caller id function wasn't working....when I plug the other end to
the phone wall jack box.....Lockups Galore.... Using the round high speed phone cable with the microfilter I had ZERO Lockups PERIOD.....
P.S. And that includes FAST channel changes & the caller ID function works.
If anything, adding the filter is what helped you. While the round "dsl" phone cable looks cool, it is absolutely unnecessary. Remember, a chain is only as strong as its weakest link, and I am sure the phone cable that feeds your house isn't made of round "dsl" phone cable. Requirements for plain old telelphone wiring are very low-it doesn't even need to be twisted.
Its good to hear you got it worked out!
--Dan
Black picture
Recent problems
