What did I hit? somewhere 93 - 105W
ken2400
1,309
144
Central NY State
So what did I hit??
12 foot solid dish with two ku LNBs. Only one working
I think somewhre between 93W - 105W?????
Oh ya nothing FTA all scram
11860 H 30000
11980 H 30000
12100 H 30000
12178 H 6500
11860 V 30000 TV4010
11980 V 30000
12100 V 30000
TV20500
TV11
TV4030
TV3999
TV28001
12178 V 6500 2way to Ku-DVB
Thanks for the help.
Your skew may be off, perhaps by 45 degrees, so you are picking up the transponders at equal power regardless of orientation.. either that, or you have a single polarity LNB, so the voltage switch wouldnt make any change
This is on a 12 foot dish, so you probably have two Ku band LNBs, one for vertical, one for Horizontal (unless you retrofitted an LNBF in there), in which case, the switching mechanisim between them (either a 12V voltage switch, 22khz switch, or DiSEqC) is not tripping. The big reason I can think for that is because blindscan does not do that, it only does a 13/18v switch. I would change the LNB type to a single polarity, or scan only on the currently selected polarity.
There is two LNB on this dish. I don't know the type tho. I did not get signal off the other LNB BUT it could be cabling. I am only helping out on this because of where I work and contracts and all.
Thanks for the input.
Is this a good system...
DirecPC LNB/Dish for FTA?
