What equipment should I get?
WakeBdr
SatelliteGuys Guru
138
Cumming, GA
About a month ago, the installers came out to install my Dish system but couldn't because of the way my house was wired and built. Since then, I have re-wired my house with two lines to each location I want a tv (4). All of these lines terminate in my new wiring closet so there is easy access to them. I am going to call them tomorrow to reschedule my install and was wondering what equipment I should ask for.
I know I want DVR on at least one tv. I was thinking of asking for 4 separate receivers because I have a need to be able to easily take one with me when I need to. Any recommendations on what equipment I should get?
Thanks in advance
That all depends on how many of those 4 tvs will actually be used simultaneously. For example, there are only two people in my house, so a 522 would be ideal, with the TV2 output sent to all the other rooms. If all 4 will be used at the same time for different channels, you could either choose a 522 to run two of them, and either two single tuner 301/311/etc or another 522 or 322 for the other two. If #3 and #4 are the single tuner models, that would make it easier to take somewhere else as only one input would be required.
If any of your tvs are high-definition monitors then the 811 is another option to consider.
It is possible that all 4 tv's could be viewed simultaneously so I would definitely need a tuner for each. I do not have a need for HD right now, so a high definition tuner is not a requirement for me.
Thanks for your input. It is greatly appreciated.
OTA digital signal threshold points
New software for the 510
