After searching the Forum I found that this topic resembles my situation the best.
I need to combine the dual outputs from my LNB into one coax then split them at my receiver to feed the dual tuners.
More info; I am about to purchase an RV that is pre-wired for satellite connections. The RV, however, only has one satellite connection. Prior to purchase I can insist (at my expense) that they install a second wire for the dual feed LNB, but I would rather not have them tear apart any part of the rig.
I am running a single LNB with dual feed to an Ultimate TV Dual tuner receiver. When the Ultimate TV dies, I will move my DirecTV HD Tivo out and while on the road loose the HD channels unless I want to deal with the triple LNB alignment issues. The single LNB is very simple to setup.
Question: Can I combine the dual feed LNB into a single coax, and then split it back out to feed the dual tuner? Is that what the Diplexer is for?
Thanks for your input/advise.
-Eric
