What setup do I need?
forget_f1@hotmail.com
Hi
I hope you guys can help me. This is what I got from antennaweb:
* yellow - uhf WGFL-DT 28.1 CBS HIGH SPRINGS FL 257° 13.4 28
* yellow - uhf WUFT-DT 36.1 PBS GAINESVILLE FL 311° 2.6 36
* yellow - uhf WCJB-DT 20.1 ABC GAINESVILLE FL 198° 10.7 16
* green - uhf WOGX-DT 51.1 FOX OCALA FL 180° 22.7 31
Note the four orientations (180,199,257,311) and the distance, furtherst being 22.7 miles. I am only interested for these digital signals for my samsung SIR-T451 HDTV tuner.
The issue is that I do not want a rotor and another remote since the orientations are spread out. I want all the channels available at the same time. The signal is going to 1 TV. I got two recomendations:
1) Get a DB8 (multidirectional with 100° beam width) antenna and aim 1 array (ie a DB4 antena) at 190° (to get 180° and 198° transmitters) and the other array at 285° (to get 257° and 311°). I am afraid of ghosting and multipath (what is multipath?). Basically two multi-directional antennas in different directiond.
2) Get a DB4, basically one array of DB8, (multidirectional with 90° beam width) and aim it at 210° to get (257°,198° and 180° - all within a 80° beam width) and hope to get 311° from behind (but the back of 210° is 30°) since it is 2.5 miles away. If I cannot receive it then add a small directional antenna to avoid ghosting.
Is choice (2) good? If I were to add the second directional antenna what equipment will I need (e.g. combiner) and more important what distance should I leave between the multidirectional and directional antennas or the two multidirectional if I were to go with choice (1) (vertical and horizontal - I have the liberty to place them in different places).
Thank you for taking the time to read this and I appreciate any help.
Stressed OTA fan.
I think the DB4 and DB8 are overkill for stations less than 23 miles, for less money get a Rat Shack U75 for $25 I get 2 stations at 235 deg 40 miles away and 1 at 18 miles off the back.
Fox 51.1 has no HD yet so that may not be one you use much any way.
I would rethink to rotor, with stations from 4 different directions a rotor would be better than several ants.
Multipath is to digital as ghosting is to analog. But, multipath prevents the ATSC tuner from locking onto the signal. Ghosting just gives you a bad picture.
Connecting 2 outdoor antennas
