Which of the 4 plugs on my 3 LNB dish to use?
macguide
CA
Hello,
I recently replaced my single LNB dish with a 3 LNB dish. It has 4 inputs on it. I have a Directivo which accepts 2 coax signals. Which of the 4 inputs on the dish should I use?
Also, right now I'm 400 miles from home, so I assume that's why I'm not getting some of the local channels (I'm probably out of the spot beam). When I get the warning that only the 101 satellite can be seen, is that because I'm out of the spot beam?
MG
Hello,
MG
The ports on the LNB are interchangeable. Pick any two........use the two outside ones to make it ez to screw on the fittings.
You are probably correct about the spot beam. After you get things running you could call DTV and tell them what zip you are in and they may be able to do something.......OR there could be an RVer on here with more experience with that.
Joe
You may be missing the 110 and 119 because your skew is off being 400 miles from where your home settings are.
You are likely outside of your spotbeam for locals as well.
The other poster is 100% right, any two of the outputs will work the same.
Calling Customer Support, not recognizing phone number?
Media Share Questions
