will the 301 receiver work with local channels
catman60
SatelliteGuys Guru
132
michigan
just wondering if the 301 will work with local channels.i called dish to subscribe to the locals and they want to replace my 3-301's that i own. they said i might not be able to get the locals with the 301.would i be making a mistake by exchanging boxes? i suppose the boxes would be there's and not mine from now on
The 301 works fine for locals......depending on where you are ;)
There are some markets that are using 8PSK (instead of QPSK) so the 301 wont work.
Which market in Michigan?
um actually the 301 WONT work if he is in Marquette
Marquette was launched as a 8PSK only market
Marquette, MI
8PSK-capable receiver required, but still QPSK
so you need a receiver that can handle 8PSK and the 301 doesnt
I did some looking and found that the 301 is NOT 8PSK
The receivers that are NOT 8PSK are as follows:
Legacy Receiers - 1000/1500, 2700/2800/3700/3800/3900, 4000/4500, 4700/4900, 5000/5500 ( DVHS unit also)
DishPro Receivers - 301, 501/508/510
so it looks like the 311 **might** be 8PSK capable
edit: the 301 isnt 8PSK capable but the 311 is
http://dishuser.org/rcvrcompare.php
so Dish **should** swap the 301's for a 311
the 311 is 8PSK but it looks like (from the installer forum) they are using 211's instead
a installer mentions how to turn off the HD part so it only shows SD channels and no formatting issue
This comes in VERY handy when swapping out a 301/311 with a 211
after d/l, activation, and guide download.
go into the local tap of the install screen.
I think its menu-6-1-8
go into CHAN DISP
change locals to SD only and DISABLE HD..
works every time.. then there are no formatting issues.
Hemi
post 10 shows which receivers ARENT on the list
as for dishpro receivers, the link also confirmed its only the 301, 501, 508, 510
When they offered to swap your 301's did they say that you would own the new receiver that you would get or be leasing it?
they said the 301's i have won't work for the locals so they are replacing them.i don't know if i'll own them or not
splitting tv2 with a 722k
DVR for Dish.
