WINEGARD SK-1000 DISH NETWORK 622
jackde
3
Santa Maria,Ca
Can anyone help me I have Dish network 622, And I put a Winegard SK-1000 On my RV, I can't get 129 to lock on the switchs. I have two lines comming of the dish to the Recevier. Winegard has help new dish, LNB I got a new recevier 211K same thing run the switchs no 129. Dish Network won't help me because its not there dish! HELP
What dish is on your house.
Had a similar problem. Site here helped. Be more specific, not general. Like run the switches? Did you mean ran a check switch if so what was result, just saying didn't work might not be the info needed to help. But haveing said that, from the looks of the switch. on the sat if you have a 1000.2 or a turbo HD dish the wangauard should work. Does your 622 use a separater if so why did you run two lines? If you run a check switch with no sat hooked up then with the sat hooked up it should find the internal switch in the lnb. Some thing about clearing the matrix. Give it a shot.
I agree with clearing the matrix first. From the manual the dish does have a DishProPlus LNB on there so you could use the separator
manual
Yes the 622 has a saparator, Check switchs lock on 110, 119, no 129 . Run check switchs without sat then with it hookup. still no 129 I have a clear view to the south. Winegard told me to take the separator off and run two lines to the 622. I'v ran it with the saparator and without still the samething. I then got a 211K to see if it was my rec, Ran check switch I get 110,119, no 129. Winegard said this rec would work with SK-1000. There sending me a new LNB to try. The SK-1000 is lock on 110,119,129
I think the dish is not set right. the correct check switch results should have 119 first, then 110 and lastly 129.
when you have 110 first you are receiving it on the 119 lnb. you probably are receiving 101,110 and 119.
I would agree the sats are not lined up correctly, but on my system listed as 129.110.119 not sure why all works fine and so on have a dish 1000 3 signal dual output lnb's, with a dpp44 and power inserter. 3 722k DVR's no problems?
that is the order they are hooked up to your dpp44, not a problem, but the 1000.2 lnb will always go 119,110,129.
we need the OP the list the order his check switch comes back as.
Can "Thanks for being an E* subscriber" charge be avoided?
One Dish Service - Two Contracts
