Working with IR and 811
melnikok
3
I have programmed my Sony RM-AV3000 from my 811 using the Teach Remote setup screen. The problem is, it still won't control the 811. Is there something I am missing? Do I have to change the 811 to accept IR instead of UHF some how? My RM-AV3000 had no problem learning the commands from the 811 IR Blast. Please help!!!
Found this in another thread
Background
When in SAT mode, the DISH 811 receiver's remote control outputs only UHF Pro commands. However, the DISH 811 is capable of receiving both infrared commands and UHF Pro commands.
Feature
With P264 software and later, the DISH 811 includes a "Teach Remote" feature that allows it to receive commands from the 8.0 UHF Pro remote, and echoes those commands in infrared via the IR blast to a nearby learning remote.
Please note:
• Only commands used for the DISH 811 receiver will be echoed back; other remote commands (e.g. DVR, PIP, TV, etc.) will be ignored.
• After teaching a learning remote, if the receiver's remote address is changed, each command of the learning remote must be re-taught so that the addresses match.
• Some learning remotes may not be capable of learning from the DISH 811 IR commands.
• Not all "universal" remotes are learning remotes.
• Use the remote-to-remote distance specified in the learning remote's user guide as the distance to locate the learning remote from the receiver's IR blast. In some cases, it may be necessary to increase or decrease the distance for optimal performance.
Procedure
1. Using the DISH Network 8.0 remote control, choose MENU, (6) System Setup, (3) Diagnostics.
2. If your receiver does not have the Teach Remote option in the System Diagnostics Tests screen, turn off the receiver and take the latest software download.
3. In System Diagnostics Tests, move the highlight to Teach Remote and press SELECT on the remote control.
4. Review the "Warning" screen that states that a press of a front panel button must be used to exit "Teach Remote" mode. Select Help for more information or select Yes to continue.
5. While in SAT mode, each valid button press on the 8.0 remote control will cause the receiver to display "Remote Control Button Pressed." Use your learning remote according to its User Guide to receive the infrared command being sent from the satellite receiver. If a button is pressed on the 8.0 remote control that is not used for the DISH 811 receiver, the command will be ignored and no message will be displayed.
6. When completed, exit "Teach Remote" mode by either pressing any front panel button, or leaving the receiver alone for at least three minutes. NOTE: Even if the receive front panel buttons are locked, you can still exit "Teach Remote" mode by pressing a front panel button; the front panel locks will continue to operate.
I took my remote from my 311 and changed the remote address to 1 (it was set to 5) on my 811. This allowed me to teach my Sony with the 311 remote. I did everthing that was suggested by jwprimetime. It all worked, but the address on the 811 was still 5. I could not change the address with the Sony remote. I had to do it with the 311. When that was done, the taught commands on the Sony did not work at all. I cleared them and used the 311 to teach it and it works fine.
Is there any way to turn off the IR recieving functions of the 811? Mine pics up my 311 remote from the other room at times. Kinda funny how IR can bounce around 3 walls!
cswrench: Just change the remote address. I'll guess they're both "1" right now. I'm not sure, but think that changing the 811 UHF address will effectively change it's IR address, too. But changing the 311 will certainly do the job.
DISH 50" Plasma TV?
921 "in-stock?"
