Zinwell 6x8 Model WB68 for FTA?
ikki
922
12
Minnesota
Zinwell 6x8 Multiswitch
Can this device be used for FTA?
I want to use it for 97 101 and 123.
Ideas are welcome
Anole
11,819
14
L.A., Calif.
Did ya try a search for info on the switch?
As I recall, it can be used as a 4x4 multiswitch.
The extra two inputs are not usable unless the switch is connected to a DirecTV receiver.
Mr Tony
3,892
16,982
Mankato, MN
The 6x8 WILL Work with a slimline just fine. Its the D* receiver that needs to decode the "flex" ports
FAT receivers can't figure out that flex part. Its something in the software for D*
They work great as a 4x8 multiswitch though :)
ussexplroer
272
4
picked up three of these new in box with manuals. (zinwell wb68). From what I found it can be used for fta. Just not the flexports. Also it can only do 4 receivers with just the 13/18 connected. But that does not make sense. It looks like I can have two dishes with v/h output on the lnb and select between then using a 22khz tone. Then have up to 8 receivers? So well this work? Yes I searched the forums but mostly it is related to directv stuff since the switch is more for direct tv.
Thanks,
Josh
harshness
20,387
5,448
Salem, OR
With the peculiar stack plan that DIRECTV uses, I doubt that they would be of much use in an FTA application. I was under the impression that they are uniquely compatible with the Ku/Ka dishes.
ussexplroer
272
4
Additional Info On Swtich Itself
One side of the switch consists of 6 ports. 18/13v aka 99/101, 18/13v 103/110/119 22khz/22khz, flexport 1, and flex port 2. The other side of the switch is labled out 1-8 (8 outputs to receivers). On the switch label. Zinwell wide-band 6x8 multi-sw part #: wb68 ka/ku bans followed by frequencies. 250-750mhz, 950-1450mzh and 1650-2150mhz, then there is a field support phone number. Lot number of 80302 and then a directv-approved part.
still have not found any additional info on the switch besides what I listed above. AKA the flex ports are not usable on fta and that the rest should work with a 22khz tone and a dual output lnb. When the weather gets nicer. I'll pull out my old primestar dish since it has the v/h and test it out.
Later,
Josh
null modem or strait cable
Parts question
