Warning about Dish Earth Channel Burn In.
Discussion in 'DISH Network Support Forum' started by andyin137, Jun 19, 2009.
  1. andyin137
    andyin137 Topic Starter Active SatelliteGuys Member
    Oct 23, 2008
    369
    Lompoc,California
    I dont know too much about the inner workings of New HDTVs so I never even thought about this happenning until it did.
    The otherday I was on Dish Earth Channel ,mostly liked the Music channel they had on so I left it on that station while I did other things around the house.About 6 hours later I was leaving so I went to turn off TV and when I did I had a Burn in of the Dish Earth channel.Now when you turn on TV you can see the Earth especially in a darked room.Its been 2 days and you can still see it.I admit this isnt a top of the Line TV and fortunatly the TV I dont use as much as my Other one,but it is still annoying.Oh by the way the TV is a 32 inch sylvania(so buyer beware).
    I dont know if the picture (or inprint will fade)but I will see.Just thought people should know
    I found out why this problably happenned on this Channel,usually this channel moves ever so slightly as the earth moves,but the satellitte image was auctually frozen (Still frame)I dont know if this happens all the time is just a fluke on the day I had it tuned in.I am trying some of the tricks mentioned in the Posts and see if it can get rid of the Burn in.
    #1 andyin137, Jun 19, 2009
  2. MikeD-C05
    MikeD-C05 Pub Member / Supporter
    Nov 25, 2003
    16,609
    663
    Nederland , Texas
    What on EARTH?
  3. sdschramm
    sdschramm Active SatelliteGuys Member
    Aug 21, 2007
    294
    Williamsport, PA (17701)
    If it is an LCD, it should go away soon.
    If not, try leaving the TV on channel 1 (or any other channel that has "snow" on it) or there are DVD's you can buy or burn yourself that have random "patterns" that will you play on loop on your TV.
    The randomly changing patterns like the channel 1 "snow" is the best way to remove the "burn in"
    Good Luck!
  4. whatchel1
    whatchel1 SatelliteGuys Family
    Sep 30, 2006
    9,013
    23
    Great High Plains
    Chk menus
    Chk in the menus and see if there is a diagnostic or test pattern that you can use for running to remove it. My Panny has (but it is a near top line plasma) one.
  5. Pepper
    Pepper DVR Addict~Mad Scientist
    Mar 16, 2004
    7,167
    14
    Satsuma, AL
    Sorry for the hijack, I have a question: will this method help at all for an old rear projection TV with separate R G B tubes? I've apparently watched too much letterbox on mine and it has pink stripes at the top and bottom whenever we watch anything fullscreen. How many days/weeks/months should I let it show "snow" to have any effect?
  6. whatchel1
    Sep 30, 2006
    9,013
    23
    Great High Plains
    Probably not
    It doesn't sound good to fix your problem. With CRT's the burn in becomes part of the phosphors in the tube. It is not very likely that it will fix that. Burn in with LCD and plasma has to do with the pixel staying turned on a bit and the things that clear the triggers that are allowing a little bit of color to stay on.
  7. dahenny
    dahenny SatelliteGuys Family
    May 12, 2007
    3,409
    135
    Boone, North Carolina
    To experience burn-in on an LCD, you just about have to be a dedicated BIT (burn in terrorist).
    If Plasma, hopefully your TV has a screen clean mode, which you can run for 12 to 24 hours, depending on what your manual says.
  8. papalittle
    papalittle Active SatelliteGuys Member
    Aug 19, 2005
    1,373
    Some old corn field, United States
    People really turn to dish earth channel, wow!!
  9. BuddyBoy
    BuddyBoy Active SatelliteGuys Member
    Apr 13, 2006
    502
    SF Bay Area
    Maybe an alien got up on the satellite and shot his ray gun at the camera.
    To fix burn-in your screen, go to this site: Burn-In Elimination Tool
  10. TNGTony
    TNGTony Unashamed Bengal Fan
    Staff Member HERE TO HELP YOU!
    Sep 7, 2003
    9,491
    378
    Cincinnati, Ohio, USA
    I have the Earth channel on whenever I am doing things during the day and not really paying attention to the TV, but only on my LCD TV. You really should never leave this channel on a Plasma TV (especially ones without pixel shifting-anti burn-in feature) for more than a few minutes at a time unless you want burn-in.
    All Plasma TVs I've seen have a clear screen feature to "burn out" any mild burn-in. But it does take some time.
    See ya
    Tony
  11. sdschramm
    Aug 21, 2007
    294
    Sorry, your out of luck. CRT burn in is permit. You could try the other fixes I mentioned, but you probably won't see a difference.
    I think your problem, however, is that your R G and B tubes are mis-aligned and need re-calibrated. Sometimes this can be done yourself by adjust the convergence, other times it requires a professional to open the set, and manually to do it.
    Does your alignment issues look similar to these? If so, google to learn more about convergence for Projection CRT's.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  12. Lkr
    Lkr PIT MEMBER
    Apr 19, 2008
    1,792
    I had the convergence problem a while back on my Sony RPTV and it went away after a while without doing anything. If it happens again, I now know what it is and how to fix it. Thanks sdschramm!
  13. whatchel1
    Sep 30, 2006
    9,013
    23
    Great High Plains
    LOL
    Actually almost ROFL. Love that burn in eliminator.
  14. Pepper
    Mar 16, 2004
    7,167
    14
    Satsuma, AL
    My convergence is fine, I adjust it occasionally using the TV's service mode. Unfortunately this is definitely a case of burn-in.
  15. mike123abc
    mike123abc Too many cables
    Sep 25, 2003
    21,405
    587
    Wichita Falls, TX
    I thought Dish Earth was just one of the SiriusXM channels music. Perhaps better to use the actual music channel where they move the words around to avoid burn in. Looks like they are running 6033 right now (Sirius The Bridge - Mellow Rock).
  16. Sammy033
    Sammy033 Active SatelliteGuys Member
    Dec 27, 2006
    1,188
    Yes that was funny. :D
    I still have a burn on on my HDTV that has not gone away. I'm going to try the 'white screen' thing next I suppose and see if that helps.
VigLink badge
Sucuri
