satellite 99 b - 103a 103b
jackthedude
7
i just installed slimeline with my new hd plus and my hd plus doesent pick up 103 a
and my regular direct hd doesnt pick up 99???
on the plus hd i get all 101 - 110- 119 -99b - 103b
what could be wrong!!?? please help
asap what do i do!!??
103a and 99b are spotbeam satellites. If you aren't near the spotbeams, you won't get anything. What is your zip code?
help
08846
i duno y when we installed it showed i couldnt get 99
not it sai i have 99 and 103b
what about 103a????????
wh
its odd on my regular hd reciever from direct tv i get all 101 - 110 -119 -103 and 99 says failed
on my hd plus dvr i get 110 -110 -119 -99b - 103b but 103a failed
what the hell do i do what can i do!!!
08846
wh
103b is the new satellite that is available across the country. That's what CONUS means. Your local channels are on 103a, which is spot beamed. 99b isn't available in your area, so you won't show any signals from it. 99a hasn't been launched yet.
Are all your receivers setup for 5 lnb dish? That was my problem with my newly installed HR20. The installer setup my receiver for a 3 lnb syetm instead of a 5 lnb so I wasn't getting 99 or 103. Just a thought,,,
Robin
this is what is goin on exactly
:confused:on my directv hd pls dvr i get
sat 101 OK
sat 110 ok
sat 119 ok
sat 99b ok
sat 103a failed
sat 103b ok
what does 103 a have??
in another room i have my direct tv simple had reciever
and it shows - or i get
sat 101 ok
sat 110 ok
sat 119 ok
sat 99 failed
sat 103 ok
what is goinon here??? can anybody explain?????
sat 101 OK
sat 110 ok
sat 119 ok
sat 99b ok
sat 103a failed
sat 103b ok
sat 101 ok
sat 110 ok
sat 119 ok
sat 99 failed
sat 103 ok
Two questions....1. Which 103 are you talking about on your second receiver 2. Did you read my answer in post #5?
103 on reviever 2 - i dunno it does not say a or b!!!??
and i read your post - it looks like i missing "locals" is that all i could be missing if i no "have 103a' i am so lost
what sat are all my hd on!!!??? or am i good!!?
how can i know what i am missing!!!??
What model receiver is it?
the i have the hd dvr plus - new one!? and the hd reciever
the hd dvr plus is one that gets or shows 99b ok and 103 b ok but 103 a failed
and the regular hd reciever shows 99 failed but 103 ok ..
both recievers are brand new from direct
The H20 will show 103a, 103b and 99b. There is no 99a yet. IIRC, the H20's don't show anything for 99b until the new software is downloaded. Reset your receiver through the menu, then as soon as it starts rebooting, hit 0 2 4 6 8 on the remote and it will download the latest national software. Like I said, you aren't near the signals for 99b, so it will not register anything.
what is on 103a? if i cant get that what am i missing!!? also the channle the cw i think used to be wb .. do i have to order that ? how do i get that channle!!??
Last chance. If you are getting your local hd channels, then you are getting 103a. Good luck.
103a
I also cannot get local hd channels in zip 96124. All satellites are in the upper 90's except 103a where a few transponders come in at around 36. In my other location 95401 I get the hd locals no problem. Is that because of the spot beam not available in 96124?
NESN in HD? FOXNE in HD?
DirecTV Trail Periods?
