I saw a diagram from dms international that had 8 lnbs' going into 2 4x1 diseqc switches then to 1 22 khz switch. I did a search here which I see there have been quite a few posts about these switches.
I want to see if I have this figured right. It seems a 22khz is basically an automated A/B switch. Is this correcty? If you were to setup 8 lnbs' like I described would the switch basically shut off 4 lnbs' that weren't being used? Then when you select a sat on the other diseqc it turns that set of 4 on and the others off?
Finally it looks like you guys prefer ecoda switches. Is chieta any good? I welcome all opinions and information. Thanks in advance
: but I am sure the wild thoughts are blocking good judgement.
