I often read on the forum that some of us use a combination of 22khz switch together with diseqc. What is it for? I understand diseqc switch but liitle of the 22khz. How is it connected to the receiver?
I have three dishes now each with single output LNBs. I want to feed these to my receiver and DVB card. Please help me to find an acceptable scenario for me not to plug and unplug cable each time I want to record some program on the PC. I understand that 22KHz switch will not be easily available here but please help me get an understand. Point me to any diagrams(pictures) or articles that will be of help to me.
to the forum Nyanjua. There could be several problems causing this symptom. The two most common would be; 1. your dish is not peaked for Ku frequencies. Check to make sure you are aimed correctly. 2. the DiSEqC switch is faulty. You can short out a switch or port on a switch if you do not shut all the power off to your system when connecting and disconnecting switches and LNBs.
