I set up 84e to get my Globecast channels, but I want to put another LNBf to get AMC3. G25 LNB is in the center, and I tried to use MJFlash formula to find a place for AMC3 LNBf, but had no luck: no signal I got at all
This is how I think it should be calculated:
Azimuth/Elevation for 97W: 142.6/39.6
Azimuth/El. for 87W: 131/33.6
Distance between LNBf and center of the dish (between 4 bolts): 54.5 cm
Horizontal offset should be then: 545 x sin (142.6 - 131) = 109mm
Vertical offset: 545 x sin (39.6 - 33.6) = 57mm
I tried my best to put second LNB in that spot, but had no signal!
I think, my problem is that the whole dish is tilted (skewed with the scale on the back).
Should I set it straight? And just turn LNBf?
If someone has any thoughts, please, let me know, I don't beleive, it cannot be done. In the picture below, I put a circle where I had the second LNBf for 87W:
