Identify First Run In Guide
bkushner
681
2
Audubon, NJ
On Comcast the guide Id's a program by NEW/REPEAT, E* has the actual date of first run, however I can't seem to find a way to distinguish a first run show on the D* guide.
When searching a show I do see 2 FIRST RUN/30 TOTAL but when picking a show is there a way to see if its a repeat or first run?
Brian
Well,
Whenever a show is a repeat it says "Repeat" in the description, sometimes you need to go into the whole description.
Occasionally it's not listed , but normally it's pretty accurate.
Remember, this is a Tribune Company issue of getting the correct info from the show/ network, not D*.
Tribune I believe still does the Guide Info for D*
If D* is not given the correct info, there is nothing they can do to change that.
Jimbo
Thanks Jimbo I will have to look further as I never see any programs marked as repeat, even those I know are reruns.
And just for my own personal knowledge; other than the title and a brief description how do other things like original air date, year of production and repeat change you viewing habits?
I only care for recording purposes. When I record a show - I hit it twice to record the series. The problem I have is it records every show. I only want to record first runs of that show. Is there a way of setting this up?
Maybe D* needs to find a different provider for the guide info. Through experience, I have found that both Charter Cable and Dish provide better guide info than D* does.
Under setup you can change the default recording options to only record first run episodes. You can also change the default number of episodes to keep.
If that is the case, why are they both so drastically different?
There's a significant difference in the information in the guide data and the information displayed in the onscreen guide. The problem is not with the data not being in the download but with it not being shown onscreen. Ask DirecTV to show more of the guide data onscreen.
Signal Loss on some HD Channels
Dod ???
