New AMC-14 and E-3 Info
If we figure 200 ft (1/25th of a mile give or take) then we have approximately 1125 satellites in that space.
Nope, not likely they'll hit :D Decidedly not a zero possibility; but clearly it ain't as easy as some would make it seem.
Not to mention they're not all in exactly the same orbital plane. There will be small differences in the distance from the surface (or center), making it even less likely there would be a collision.
One thing is for certain with all this movement and planning going on, Dish is playing catch up to a more well organized DirectTV.
In fairness to Dish, what you are calling "a more well organized" DirecTV is largely due to failures that were in no part caused by Dish. Could anyone have foreseen the failure of both launch platforms (Sea Launch and ILS) on consecutive launches?
These sats were supposed to launch the better part of a year ago which would have made the "lead" by DirecTV much smaller.
I think the reason the new HD channels were officially announced as SOON is because Dish is trying to keep their top tier customers from jumping ship.
Dish knows their most Savvy and generally most paying customers frequent this forum and watch Charlie in all his glory on the Charlie Chat.
We are but a blip in the churn. More realistically it's to get some advertising going.
Lest we forget, DirecTV had a two year + period where they were smoked by Dish's HD channel count.
Hopefully Soon translates into about as soon as DirectTV's launch last year. I think it only took them about 30-60 days to light up all those channels once the bird was in the sky.
Time will tell.
For those of you wondering about hooking multiple receivers to a single port or even a dual port LNB, the answer is very easy. A splitter providing power through one leg is all that is needed. Whether it be a four port splitter serving 2 dual tuners, or an 8 way splitter serving 8 single tuners. A bandstacked single orbital would be easy, in fact, I dare say it would be easy as cable. One line from the dish. That line could be tapped multiple times as long as the final receiver was getting enough db and a clean signal to noise. Only one receiver would need to power the LNB and only one port at that. Now, once you add multiple slots in, then the install becomes as tricky as a normal "dishpro 500 install".
How did you guys reconcile 5:30pm with 7:18pm and conclude that it had to do with the date ??
At 5:30pm, you will have to wait at least 48 minutes no matter what time zone you are in...
They usually have a long prelaunch show. They will show the satellite being put together, it moving around, graphics of what it will do in space, etc.
In central time it starts at 5:30 and goes to 7pm on my guide. So assuming 7:18 eastern, 6:18 central. 48 minute prelaunch show and an hour+ in case of launch delays and some of the coverage after the launch.
Is someone noticed this launch Swedish company SAAB included into startup procedure.
Why is that ?
SAAB Space provides telemetry antennas and frequency converters & receivers for satellites (including dbs antennas), as well as launch vehicle separation systems and onboard guidance computers to various space launch contractors. They are heavily involved in the European Ariane program, as well as the US and Russian commercial and government programs. In this case, it's the separation system that's being referred to.
I got that info too, but my point was - are they involved in the on-site procedures first time ? Is it telling us original Russian separation components has been compromised and E* force to replace it by SAAB type?
No, Proton rockets have always used SAAB separation systems, so it wouldn't be that. SAAB's not generally mentioned, but they're usually there to monitor their hardware, along with a dozen other support companies.
Adding a 4th Sat to a two dish (3 Sat) Setup
Blacked Out on the NHL network
