Anybody own a Stab MS220 ?
looks like its designed to be used with a receiver that DOESNT have Diseqc 1.2
Most have that but I guess if you had a box like the Viacast that has no motor operation it would work for that ;)
looks interesting
The only thing I could think of using this for is if you had a receiver that didn't support usals or discq.
later,
Josh
I was thinking about using it with a DVB card. I would really like to know if it requires a receiver or if it can act as a stand alone unit, supplying its own voltage. Also It says that it displays the rotor position. It drives me nuts that I get no feedback to tell me what the motor is actually doing.
I was thinking about using it with a DVB card. I would really like to know if it requires a receiver or if it can act as a stand alone unit, supplying its own voltage.?
No receiver needed. It supplies its own voltage and DiSQC commands to the motor.
The MS220 will require you to buy a 220V to 110V adapter from Radio Shack. It is a European version and they didn't have a NA version. With the power adapter, you should be all set.
Thanks!
Does it have USALS support also?
UPS Back-up Protection
help recieving audio
