Hi, I'm replacing my current antenna with an HD antenna. It currently has old RG5 along the entire run. Do I need RG6 or will RG5 work? It's about 80 feet.
Yes, replace the old RG59 with new RG6. What antenna do you currently have and what are you replacing it with?Hi, I'm replacing my current antenna with an HD antenna. It currently has old RG5 along the entire run. Do I need RG6 or will RG5 work? It's about 80 feet.
I strongly disagree,If the RG-59 is in good condition it will work for OTA just as well as RG6
Do you mean RG-59? I have never heard of RG-5.
If the cable is old; I would replace it with RG-6 anyway. The UHF performance will be much better with RG-6.
Glen![]()
Another inaccuracy. The satellite signal is converted to a much lower UHF frequency(around 450 MHZ) by the LNB to facilitate longer cable runs without excessive signal loss. OTA frequencies go over well over 700MHZ. (Apples & Oranges) How can someone have over 4300 posts and speel out such inaccuracies???? "Please look before you leap". It's hard to believe no one else questioned this. I don't even have satellite. I can't post URL's yet ; but a quick google search (LNB) should fill in any blanks.Satellite signal goes up to 2.5 ghz TV antenna is low frequency by comparison.
BTW; thanks guys for the info on RG-59 vs. RG-6 cable.
Glen![]()
Thanks for the responses! I'm upgrading from a 25 year old VHF only to a Terk HDtv Amplified Antenna. Link - Amazon.com: Terk HDtv Antenna Amplified: Electronics
Charper 1 I agree for $75 they could have bought a real antenna. But I also admit for many of us TERK is a four letter word.
Glen![]()
You guys paid more that $30 for that antenna? I am not being a smartass when I say there are far better choices for the same and less money.
Here you go. Hope this review helps. I love the CM4228 and you can build your own for less than $10. http://www.satelliteguys.us/hd-over-air-ota/119733-very-good-2-00-homemade-antenna-hdtv.htmlGive me an example.....
This Terk is proven and for the distance I am out from the broadcast towers, it's perfect (about 42 miles). I "one-clicked" on Amazon and it was shipped to my door for free. Showed up 3 days later.....:up
