Strange looking feedhorn
Corrado
2,428
303
Hudson Valley Region, NY
Anyone have any ideas about this double ended looking LNB on this dish?
I'm hoping to take this one home someday.
Thats a "SeeVee" c-band only, I used to use 1 back in the 80's good working feed, even had a C & Ku SeeVee feed their 1st model that they made.
yeah i looked up seavey but the newer ones only show a dome on the bottom of the feedhorn, so i didn't post about it
would be nice to get a upclose picture of it :)
the other dome was a protective cover that would cover up the servo motor conections, the servo had 3-screws on it where you put the wire in then tighten up the screws, like you do a actuator today.
when I got that feed (this is maney moons ago) that is when I changed from a LNA & down convert to a LNB an if I remember right put a 75 degree on it, was the lowest you could get back then.
also in the little dome will have a antenna that looks like a butterfly that the servo motor turns, now a servo motor of today will NOT fit on that feed, it takes a servo with a square drive sticking out.
