Will an HR22 Allow me to watch D* on two tv's?
lgjmb
Jul 20, 2008
8
I used to have an H20 receiver which allowed me to watch programs in my home theatre and bedroom. I ran the signal to the bedroom through the TV out (I believe it was called that). They were the same programs, but it gave me the option of watching tv in either room. I had to replace it with an H21, but I lost the option of watching tv in the bedroom. Would an HR22 allow me to watch tv in both rooms? If so, are there any special requirements?
Thanks,
jtwex
828
Embarrassed Bear
Thanks,
Haven't seen a TV out in a while but why wouldn't the TV out work with the H21 as it still delivers the signal to the TV. That aside, you can use any of the free outouts on the HR22 (ones not being used) to run to your bedroom; you will just be required to watch the same program on both TV's. If they are close, you can run Component/Composite directly to the bedroom or purchase an RCA to 75 ohm modulator & run Coax to the bedroom. You could also run HDMI directly to the bedroom but I usually save that for the best TV. All outputs on the HR22 are active for feeding different TV's.
Zynergi
938
NC
Exactly, if it was working on your H20 then it will be the same for any HD Rec. You may have had a RF modulator on the H20, which doesn't sound like you hooked that back up when you put the H21 in.
jacmyoung
3,009
Sacramento, CA
I think what he meant was the H21 no longer has the RF out so he lost that simple connection. I don't think the HR22 has the RF out either. What he can do is to buy a composite to RF modulator and convert the red/white/yellow to RF.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,802
17,748
Cheshire CT
H20's don't have rf outputs. It must have been connected some other way.
U235
50
Beware though, I'm having many difficulties with this. It does not appear the HR22 and an RF Modulator can share an RG6 for the satellite and UHF feeds, there appears to be some interference.
If he does it this way, I think he'll need a separate run from the RF modulator to the TVs, he will not be able to utilize the same RG6 cable.
rad
Cutting Edge
Sep 7, 2003
11,454
5,912
Dripping Springs, TX
You can't diplex RF signals on the same wire as the sat feed because the way D* has stacked the DBS signals they share the UHF band.
