Got the LNB today!
Cold fingers and wet from raining but I managed to install the new Invacom TWH-031. This LNB is huge and wow it's pretty heavy, this is a real dishes LNB! Going to have to upgrade that LNB Bracket now for sure!
So far very happy that I decided to purchase this LNB and I can't believe how fast I received it. I would love to write a review but hey this will do. :up
On average I saw signal gains of about 5 to 7 over and above the Fortec Star Universal LNB. 11750 on the Fortec Star LNB was around 48 to 52 depending...Now with the Invacom I am getting strong solid 62 to 64...67 to 70 on some transponders.
In the Fortec Stars defense, today I re-adjusted it and was pulling in much better signals even with the rain and clouds. I also solved the problems with Channels showing up Horizontal when they should have been vertical.
When I originally installed the Fortec, I couldn't get a signal at all but only in one spot. Today I saw why, something I had overlooked which I thought would not cause a problem. It did clearly because when I removed it, I was getting a good signal improvment. Interference, I would suppose maybe, and I didn't put that bracket back on when I installed the Invacom...
I forgot to mention, the Fortec Star after I got the bugs worked out picked up from 48 to 52 to 52 to 56 so it did improve but not as well as the Invacom. Maybe with more tweaking...I really didn't tweak the Invacom very much because of the bad and cold weather here...
Over all I would recommend this LNB to anyone, I would also say the FortecStar Universal is not a bad choice either...Being as fair as possible!
:up
