How many coax cables will I need from dish to receiver.. I will have HD DVR package.. I already have one coax now, from when I had D" 8 years ago..... I only want one tv to work.... Will I need another coax? I live in PA..
Depends on the dish you get. If you are getting signed up as a new customer then you *should* be able to get a SWM, but being in PA they might not be installing them due to cold weather issues. If you get a regular dish you will need two runs.
I will be considered a "new cust"....I was under the impression I would need a SWM, b/c of HD....They install regardless of weather....
The reason I'm asking about an extra coax is b/c I must remove a few ceiling blocks b4 they come...
You are thinking slimline. Slimline is the dish type, SWM means single-wire multiswitch and refers to the type of LNB (the thing on the end that the cable connects to). You have to have a slimline dish to get HD, but you can get a standard LNB that is non-swm with that dish. SWM has been standard for new customers, but there is a problem with a certain brand of SWM LNBs that are locking up in below 0F temps. They might not be installing them again yet.
Yep I have a central location where the cable runs into the house. No splitters on any lines. Thanks.
For the DVR they'll need to run an additional cable, unless you get a SWM (not likely).
Sorry for the confusion. But would they need to run 7 lines from the satellite to the Multiswitch (The central point on the side of the house) and then the 6 lines that are part of the existing wiring are sufficient to supply the 6 boxes? Or would they need to actually run that 7th line through the house and to the family room and ultimately into the DVR?
