If I buy a dish can I pick up non-HD channels?
If you buy a dish that is larger than 31" (I recommend at least a 36" dish) then you can pick up FTA signals, I would also recommend getting a motor because FTA is spread out over many satellites. Take a look at TheList
to get an idea of 24/7 programing (Most 24/7 FTA channels are in SD), during events you can pick up temporary feeds.
Bob,
I have to agree with Qwert on the subject of the dish. At minimum you want a 76 cm dish which is about 31 inches. And a motor is really a necessity. The FTA channels are spread out all over the horizon, so you may pick up one or two great ones here and 37 there and 16 over here and 3-5 over here, etc.
Not great when you just pick out any one satellite, but a huge benefit when you can use them all. That is why you should have a motorized dish.
When it comes to the physical size of the dish antenna, that can be misleading. Just because a 76 cm dish is smaller than a 90 cm dish, does not mean that the 90 cm dish will pick up more channels or pick them up with better quality.
It depends upon the overal geometry of the dish. The affective apperature of the dish is what you need to be looking for. If my 76 cm dish has an affective apperature of (let me pull a number out of hat here for discussion) 86 cm, but another dish that is 90 cm has an affective appearture of 83 cm, you had better go with the smaller dish.
In this case, the smaller dish is also better, not only because it's affective apperture is better, but a smaller dish has a better wind resistance (it is less of a sail).
The other charicteristic that you want to look at is the gain of the dish. The higher the gain, the better.
All of these charateristics do not always go hand in hand, so you have to weigh each one individually.
Personally, I use a 76 cm dish and when it is aligned properly, I can put it up against nearly any 90 cm dish. But, that is just one model from one manufacturer (Winegard). Other dish antennas of the same size may not compare so well. This is why you have to look into the specifications.
Radar
