They way that's written confuses my head. I have read it slowly bit by bit.Unfortunately HW/FW and the error correction protocol cannot be changed that way what you using. I would say you're lucky to have the receiver what could lock with the wrong FEC command.
But inside of it it will do that job if it use correct value.
Short, you cannot cut variable number of bits from one packet when the count predetermined as per FEC value [created] before uplink.
Let me say other way - you can't start engine after you fueled 78 octane gas by changing tires or just telling the engine - "Start it !".![]()
So what you're saying is:
It don't work that way. If it's not all set right I won't work
Response: I would only be looking for it to lock on to the transponder one way. The right way in respect to freq., pol., sym. rate, and FEC.
However I've only used TSReader with my Hauppauge HVR-1600 ATSC/QAM
I don't know how the exact workings of TSReader and a USB or PCI DVB-S/S2 device would work. I don't claim to.
I've only read the older threads with yourself and other owners going over the paticulars.
What I understand is some IRD's and PC software can give the info back.
I don't have anything that will give me that info.
So I put a call out here to ask those that did have the various IRD's to check.
I never claimed to be able to magically change the transponders FEC, or even that I thought it would give me better signal be forcing my IRD to pick up the transponder quality by chucking out packets.
I don't know how AcWxRadar got any of that. Poor sick man.
I wanted to know if Mike 's list and Lyngsat were out of date, in the case that they changed the FEC rate Tuesday.
No probable, but I wanted someone who could, to find out and tell me
So again thanks to everyone for your help.
