Ideas about mounting new 46" HDTV
jcarrera
901
Florida
I just purchased a 46" HDTV and would like to hear Ideas about mounting it from people who have already done such.
Some of the questions I have are
- what kind of mount hardware to buy?
- best way to hide cabling (power, audio to/from receiver, video from STB, cables from DVD/VCR machine, and the cable from the internet video delivery box...don't know what that connector is yet
- any general tips from whoever has done this before (any mistakes to avoid or things you like about your installation)
- will BHN run a cable to the new area where TV is to be?
Khandurian
398
Cocoa Beach Baby!
If you goto best buy, they will tell you which hardware you will need to purchase to mount on the wall. Last I checked, they also had the ability to install it on the wall for you. (this may have changed so don't hold me to that part)
I just did this for my brother. He already had the tv mounted, just needed the cables ran. I cut a hole that will be hidden by the tv, and just ran the jumpers to almost the bottom of the wall where the other wires were already ran. Inserted a small wall box, put a 4 hole wall plate for audio/video/hdmi/cat5 connectors.
No wires visable from receiver to tv. Looks nice, and is real simple to do.
Take your time. Don't rush things. Improper mounting of the hardware will cause a big expense later down the road. Hire a contractor to do it for you. In the long run, it will be worth the money. You can sleep at night knowing its not gonna fall off the wall in the middle of the night!
Yes, if there is no existing cable on that wall, they will run it. It will cost $49.99 to run the new wire from the splitter (outside or attic access).
jcarrera
901
Florida
More info on the wall plate please...where did you find one that would hold the exact complement of jacks you needed? I don't know my specifics yet, but just as an example it might be I need video coax, HDMI, component (DVD/VCR does not have HDMI-out), an audio coax or optical, cat5, etc etc. My point is, where did you find a plate to serve as the wall patch point for wall-to-component stack cables-- that will hold any shape/size of jack you need?
jcarrera
901
Florida
After looking at the room, contemplating the physical setup, and the wiring effort, I am thinking about going commercial for the installation. So, I looked on the web for ["home entertainment center" installation Melbourne fl] and found nothing.
Does anyone know of a business that does home electronics set ups in Melbourne if you don't buy the hardware from them?
jcarrera
901
Florida
A new angle to the installation question...
The discussion is regarding HDMI from STB 8300HD to the TV (possibly through the AVR)...
I have read elsewhere that there are sound issues with HDMI and the BHN DVRs. Does anybody know what this problem is and do you have any recommendation to use component or go ahead with HDMI?
krauser1
289
8
Atlanta, GA
Another suggestion, since generally wall mounted TV's are "clean" installs and nothing is showing, I would use an RF remote. That way regardless of where your cable box or audio receiver is, you can operate it without having to "point" a remote at it. I have all of my equipment in the closet in my office with an RF remote. Ran RGB cable to TV and speaker wires through basement. Nothing shows and even though I have a dish HD box, yamaha receiver, and an XBOX, none of it shows having a RF remote.
jcarrera
901
Florida
That sounds like a very nice setup, but the only place I have where I could hide the equipment is a LONG way away from the TV room--makes cables too long.
Know anything about the sound problem with HDMI?
FiOS' answer to News 12?
Ion HD?
