Now that I have thew ability to update my Coolsat 8000 I just updated it with version 2025
WOW!! Talk about night and day. And with a few others acquiring these pretty inexpensive recently maybe this can help
Comparisons with the new version versus the old (1440 I think it was). All are upgrades
1. the satellite list. Other than AMC21 its up to date with names! I actually see "Horizons 2" as the satellite for 74W and not "Galaxy 6" which hasnt been that for years. The new version has AMC instead of GE
2. The list goes from E to W...use to go W to E...ie it starts with 1.0 and then the next one etc..so for the normal sats it shows 72, 72.5, 74, 77, 79 etc in order
3. all the eastern satellites are gone. Use to have to delete like 20 satellites that were XXX.0 E. Dont need those
4. The 31 satellite limit is GONE! Use to have a limit of 31 satellites so if you were KU/DBS you actually ran out of slots. This is now gone. Now I might motorize it
5. When you manually scan after it logs the channel it goes to it. Previously it would go back to the manual scan option
6. Transponder list is semi-up-to-date
7. reservation (for timers) is on top of sort (was the other way around)
Sadly it still sorts the channels horribly with a lot of channel 0001 which proves this was a hacker special (since Dish channels would be 0100, 0101 etc they can sort by sid)
Other than that it looks like the same firmware. So this is an upgrade
I enclosed 3 things
-the loader. Its kinda weird as you have to run the program that shows "1" first, then "2" which loads the info. Then the loader itself
-clean. This allows you to "clean" the software. Actually it allows you to go backwards on software. Normally it wont
-the file
need a null modem cable. Anyone else notice any differences between the old software and the newer one?
I enclosed 3 things
-the file
