First Time Dish find need help/info
Long Hair
374
52
Mo
I have found a 7.5 Unimest dish from a steel yard, it was out of the ground on the pole with concrete. Called them up they said take it, so I said sure. But I didn't get the pole to heavy for me. So I would like to hear what you guys think of my find, and tell me if it looks usable or not I should have some pics for you to look at. Oh, some info Chaparral mini mag LNB #140011 65db. and 20k. The actuator Super Jack II+ HQ Pro Brand International, The Shaft measured at 20in. Look at the pics and let me know what you think about the string test.
Thanks for any/all the help. Long Hair
I don't like how far apart those thick strings are in the last picture... :(
Looks like the reflector needs to be mounted and tested again 'cause it might need some adjustment. :up
Looks like the reflector needs to be mounted and tested again 'cause it might need some adjustment. :up[/
I did the string test again, the string was loose. Now the strings are touching,a little tight.
NOAAPORT help
DIGITRANS DTE-7100 DIGICIPHER II 2 RECEIVER
