Help with setting up DVB-S2 on a Diamond 9000HD
mikelib
2,110
1,076
Jersey Sure
I recently picked up a Diamond 9000HD-PVR receiver. It has software version 1.31p (yes I know it is not the factory firmware version). I purchased it to receive DVB-S2 channels in particular the Florida Channels on AMC-3 87W; the two channels are DVB-S2 and 8psk. I tried last night to set the receiver and transponder settings to the correct value for these channels. I was not successful.
Can any one help with the setup?
Also does any one know what other KU DVB-S2 channel there are to try with this receiver?
Tnx in advance,
Mike Lib
If I remember correctly you have to add the TP via the channel editor then load it back int he receiver
Louisiana PBS is also S2
AMC21
12072
H
16666
3/5 fec
pilot off
edit:lak7 beat me to it
EDIT:
Since you have 1.31 loaded, you should be able to save the Channel List to a USB Stick.
You also need a Straight Through Serial cable, not a Null Modem, to connect and upload / download the Channel List
I have to try the memory stick trick
Since you have 1.31 loaded, you should be able to save the Channel List to a USB Stick.:)
I have the NDFEditor version 1.57, there is a version 1.58 on a hack website and I did not want to register to get it. I also have a null and a straight cable.
I take it that you can put the diamond.ndf file on a USB memory stick and use that to transfer it to the receiver. I will have to try that.
AMC21
12072
H
16666
3/5 fec
pilot off
Ice, how can you tell when to turn the pilot on or off. I have entered the pilot on for the two Florida stations?
Thanks guys for all your help, I will give it a try and I will let you know if it works.
there are "ways" to add s2 via remote on the diamond... I have not used the editor in 2 years, but i watch s2 all the time... I use modded firmware.
KU mux is 12000 H 30000 8psk 5/6 ON AMC 1 103deg.
AMC21
12072
H
16666
3/5 fec
pilot off
Is this a tough transponder to get? I 11989 just fine, but I don't get any signal on this one.
Yes, there are "ways" to do it, but no efficient. You have to load a Modded Firm, enter the TP info, then re-load "regular" firm to watch. It's just faster to use the editor.
Don't you just love this hobby????
With LAK7 help I was able to get the DVB-S2 transponder into the editor onto a memory stick and loaded into the Diamond-9K-HD receiver. I set up the dish and swung over to AMC3-87W, I locked in the SD transponders, but had no SQ on the DVB-S2 transponders. The dish is a metal 90cm.
Has anyone locked the two Florida channels if you have can you share the transponder frequency and setting??
tnx
Mike Lib
I can Lock both at:
12044 V 3200
FEC: 2/3
Pilot: Off
12050 V 3200
FEC: 2/3
Pilot: Off
Signal is not as Strong as the 11720 TP
EDIT: should have mentioned it is using my 80cm "Bob Jones" Dish
I can Lock both at:
12044 V 3200
FEC: 2/3
Pilot: Off
12050 V 3200
FEC: 2/3
Pilot: Off
Thanks I'll give it a shot tomorrow, weather will be sunny in the low 70, here in lovely southern NJ.
No Luck
So far The FTA Gods are against me, I'm sure that I have the receiver set up correctly, but I still have no SQ on those two transponders. I realigned the motorized 90cm dish a few times change the Universal Chapparal LNB to a Standard Ivacom that does both linear and circular and still no SQ. Tomorrow is another day, does any one have any good prayers for the FTA Gods??LOL
Mike Lib
What is your Q reading on the 11720 TP?
11720 H 4858
LAK7 - I was out all day, went to The Gloucester County Amateur Radio Club, flea market and saved a Coolsat 5000 from someones dusty garage. I will try again tomorrow. Thanks for your concern and help.
Mike Lib
where am I?!?
Question about switches
