Hi,
Is there a DisEqc 1.2 36 volt actuator positioner which will support the DisEqc 1.2 command '6E GoTo x.x'? This is a five byte data command used to position a motor. Typically the motor is an HH type where the data represents degrees. In my case however, I am using an actuator to position a 6 foot FortecStar prime focus dish. The polar mount will be modified to add a rotary encoder located at the axis of rotation. The encoder will be scaled to represent degrees, which is compatible with HH motors. The micro switches will no longer be used. The 5 byte 6E command should not to be confused with the satellite position index value,which is the 6B command GoTo nn; where nn is a 4 byte value. The command bytes can be found in ETELSAT “bus_spec.pdf page 17.”
Any comments are welcome.
