No signal on new setup
onceydoce
10
Blue Grass State
Saturday i bought a 1.2m FortecStar with a Sadoun DG 380 from Sadoun.So far so good.
I setup the dish including the motor on a plum 2" pole in my yard.
My setting are as the folowng:
My Latitude: 38.95,Longitude: 84.66
Motor Latitude:39
Dish Elevation 29
For the setup i am using a TechSat Trecker II+ lnb.
I tryed to aim the dish at AMC 3 & 9 since they have the best proximity to my true south.I choose not to use AMC 13 since it only has feeds on it.
I tryed the following TP on these Birds:
AMC3 11736 V SR 8333
AMC9 11735 H SR 4444
On both i get a Q ranging from 78 - 91 but no S at all.
What am i doing wrong?
I hope someone can give me an adives or two how to get all this setup.
Thanks in advance
Onceydoce
L.O. looks good at 10750.
Using a compass, you should be pointing to 185 South.
Double check you are using the correct indicators for the Motor Lat and Dish Elevation.
That TP is not the easiest to hit, I would try for AMC3 first.
Just a thought, Why do you have the lnb set to 18v. If you are not going through a switch shouldnt it be set to ON?
Something to be proud of.
V box usals diseq and goto questions
