I hope I'm not the first to experience this......I need some help.
My 722k is acting very strange. I'm having two problems:
1. WHEN the TV1 remote responds (and its a 50/50 thing) it is extremely slow. I'm using a 20.0 IR remote for TV1. I figured it was the batteries so I installed new ones.....the problem is still there.
2. This problem is even stranger. When TV1 goes into standby mode, I get the "Press SELECT to Watch TV" message. I can press "select" on the remote 100 times and nothing happens. In order to wake the box up from standby mode, I must press the "select" button that is actually located on the 722.
TV2 is not having any problems.
The ONLY thing new to my setup is that I got a new TV. TV1 used to be a SDTV hooked up via composite cables. Now it is a HDTV hooked up via HDMI. The problems started to occur immediately after hooking up the HDTV, so it would seem that is where the problem is, right? That just doesn;t make sense to me.....I've heard bad things about E*'s HDMI ports.....could that be the problem?
Thanks for the help. This thing has been driving me crazy.
		 I actually jumped the gun and posted too soon.....I just went over to the tech forum and read about a similar issue.  I turned off the Dynalight(??) and Dynamic Contrast on the TV and the problem is solved.  This forum is truly a wealth of info! :up:up
