I'm still in the process of engineering a work-around on my C/Ku band project in regards to how I would be able to connect it to the whole house TV network. It looks as if I might have to put a 2 x 1 switch in and just dedicate the switch's output to only the living room. This brought about the question on how I will connect the satellite dish to the 5 x 8 Multi-switch. Somehow I had stumbled across a couple of links on the Sadoun's web site for a Toroidial dish (T55 and T90).
If you're not familiar with a toroidial dish, it operates a bit differently than offset dishes. It uses two reflection paths - one from the satellites and one to reflect into the LNBFs. The LNBFs are installed on a curved bracket which allows the installer to install up to 5 LNBFs and adjust the skew for each one.
I am very curious to know if anybody has or is using one at their home and how well it works for you. The toroidial dish seems like it will solve my rain fade problem and also offers reception of multi-satellites within a 40 degree range without a motor. I like the idea of using it to pick up 83 (RTN), 97 & 101 (GloryStar), and possibly 119 (NASA, ION, and Angel One), but I want to hear from others how well it works for them before I spend money for it.
		 When they say 40 degrees, does that refer to 40 degrees on each side of the 0 mark or is it 20 degrees on each side of the 0 mark?
