I hunted around and found an e-mail I sent to another member on cutting into the Cyberhome headphone cable to use the inline amplifier. This will give you more level to your AV system or tv.
> In case you get the nerve up to cut into the headphone cord, I just opened
> up my splice and looked at the wires you will need. This will save you
> some time tracing out and experimenting. Of course the cord is double
> cord, one for left, one for right. Split it apart and strip off outer
> jacket. Inside you will find four bundles of colored hair wire. They have
> very thin insulation on each hair and you can burn thru the insulation by
> "tinning" the end of each bundle. This is six channel audio, you only need
> two, the others are unused by the sat audio. 1st cord...
> red - unused
> green - unused
> red/green - left audio
> gold - shield or ground
> 2nd cord...
> red - unused
> green - unused
> red/gold - right audio
> Jim
Use the volume control on the decoder to boost the level to match your normal tv audio. Standard sat audio passes thru automatically so you don't have to switch back between AC3 and standard.
You can buy these off of Amazon for less than $20.
Amazon.com: Cyberhome CH-SRD 600R 6-channel Surround Headphones with Game Decoder: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31s7uUYDl8L.@@AMEPARAM@@31s7uUYDl8L
> red - unused
> green - unused
> 2nd cord...
> red - unused
> green - unused
> Jim
