The 722K only provides Dolby 5.1 thru the optical port for use with a external decoder/receiver.
The HDMI output on the receiver is designed to output Video and digital PCM only.
You are mistaken.
TNGTony said:As mentioned above, if you hook up a TV though HDMI, the TV is getting DD5.1 fromt he receiver. But there is no TV on the market that will take that DD5.1 signal and pass it through its optical output. This is by design to prevent pirating. It does nothing to stop pirating and is the most idiotic thing on the planet, but that's the way it is.
See ya
Tony
Not true. I have my Sony XBR9 hooked up via HDMI from my VIP622, then optical out from the TV to my surround receiver and I get DD5.1 out of my sound system. My neighbor has the same setup with his new Samsung C8000, and he gets DD5.1 as well. So some TVs will pass the DD5.1 signal through.
No, he's not getting 5.1 from a STB.
This is copied from the Samsung UN-46C8000 owner's manual.
When the receiver (home theater) is set to on, you can hear sound output from the TV’s optical jack. When the
TV is receiving a DTV signal, the TV will send 5.1 CH sound to the home theater receiver. When the source is
a digital component such as a DVD / Blu-ray player / cable box / STB (Set-Top-Box) satellite receiver and is
connected to the TV via HDMI, only 2 CH audio will be heard from the home theater receiver. If you want to
hear 5.1 CH audio, connect the digital audio out jack from your DVD / Blu-ray player / cable box / STB satellite
receiver directly to an amplifier or home theater.
Like I said previously, "it was probably something stupid I did". Went back through the input assignments and found that the audio was set for OPT1 on the HDMI input for SAT. I actually think I did that out of frustration when I wasn't able to get DD/5.1 over HDMI when I set the Onkyo up last November. Anyhoo, when I cycled through to ----- the receiver then defaults to DD/5.1 over HDMI! It wouldn't do this before, dunno why, but it does now.Thanks again for the helpful replies--appreciate it!:up
Ed
Glad we got you to go thru the menus and fix it. :clap Now it's partee time.![]()
Naw, now I'm pissed 'cause the 722 doesn't send 7.2 DTS HD Master Audio!
Just kiddin'..............
Ed
Never had an issue with this on any dish receiver (including 922, 722k, 722, 622, 211k, or 942)
Do you know what audio settings do you have to enable? I just can not get it to output anything
but PCM stereo.
menu 6-7 Dolby Digital/PCM. I also have RF as mode (don't know if that is needed or not). Then that will be output thru either optical and/or HDMI. Most nets only have the stereo, only some have DD.
Your Sony XBR9 only outputs optical 5.1 DD when the set's ATSC tuner is receiving a broadcast with DD. If you are viewing something via HDMI or any other source other than OTA the optical output is 2 Channel Stereo only. You've been missing a lot audio wise if you are viewing satellite via HDMI and using optical out from your XBR to your surround receiverNot true. I have my Sony XBR9 hooked up via HDMI from my VIP622, then optical out from the TV to my surround receiver and I get DD5.1 out of my sound system. My neighbor has the same setup with his new Samsung C8000, and he gets DD5.1 as well. So some TVs will pass the DD5.1 signal through.
What? <sputtering incoherently> I'm sure you are right but does this make sense when the optical output is not so encumbered?No TV in the US will pass though from the HDMI input. It is some idiocy having to do with copyright owners trying to protect their DD audio.
The only situation where that would be true is if you are trying to pass 5.1 through your TV optical out, which most TVs will not do with the exception of OTA from TV tuner.
When I tried it with my Dish 722k I do not get DD 5.1 just PCM. So it seems that 722k does
not output DD 5.1 via hdmi.
But it does. Your TV only outputs 5.1 when the source is the ATSC tuner.
