New PC
I am now leaning towards just replacing my motherboard/processor in my built computer. This will save me money and still allow me to continue to upgrade my PC as time goes on
You'll also need to replace RAM: modern systems use DDR3 while yours most likely not even DDR.
Also, your case power supply might have to be replaced...
Diogen.
Diogen.
DDR2 currently
500 Watts Antec case. I want to replace the case anyway because I want a smaller sized box
diogen said:
I must be missing something: 8 years old PC uses DDR2? And 500W PS?
Diogen.
I was wrong about the years. It is closer to 5 years.
Yes. It has DDR2 and 500 Watts.
I can take a pic
Decided to build and here is what I will be getting
Quad Core 3.5ghz AMD processor
6 outside USB 3.0 ports and 2 are eSata/USB combo ports
4 gigs of DDR3 ram
750 Watt case
Solid state Hard Drive (haven't decided on the size yet). I currently have a 500 gig Hard Drive and it is only 20% full. I do not store much on my computer
The rest I will be recycling from my old PC (DVD burner, video card, ex). I will take my old PC and use it as my main classroom desktop.
are you buy a barebones kit and adding to it? I don't see a mother board listed, but I do see the listing of USB ports.
No.
Here are the specs:
Gigabyte GA-880GMA-UD2H Gigabyte GA-880GMA-UD2H Motherboard AMD AM3 880G/SB850 PCI Express 2 DDR3 USB3 ATX Retail from mwave.com
Kingston KVR1333D3N9K2/4G KINGSTON KVR1333D3N9K2/4G ValueRAM 4GB kit (2GB x 2) dual channel 240-pin pc3-10600 DDR3 1333mhz DIMM desktop memory module from mwave.com
Decided to go with 6 core instead of 4: AMD HDT75TFBGRBOX AMD HDT75TFBGRBOX Phenom II X6 1075T 3 GHz Processor - Hexa-core - 3 MB L2 - 6 MB L3 - Socket AM3 PGA-941 - Box from mwave.com
Antec EA-650 ANTEC EA-650 earth watts ATX 12v v2.2 eps 12v v2.91 650w 80 plus / nVidia sli certified ul & fcc active pfc power supply for ATX cases from mwave.com
In Win IW-Z638T.CQ350TBL In Win IW-Z638T.CQ350TBL MicroATX Mini Tower Computer Case with 350W Power Supply, Black/Silver from mwave.com
Decided to not go with a solid state drive: Western Digital WD5001AALS WESTERN DIGITAL WD5001AALS Caviar Black 500GB 7200 RPM 32MB cache SATA 3.0Gb/s 3.5" internal hard drive (Bare Drive) 5 years factory warranty from mwave.com
My buddy no longer works for MS, so now I have to buy my own OS: Microsoft FQC-00765 Microsoft FQC-00765 Windows 7 Professional 64BIT English DSP OEM 1-Pack from mwave.com
And this will supply enough power to the USB ports to quick charge my devices and even charge my iPad: http://www.gigabyte.com/MicroSite/185/on-off-charge.htm
I didn't want to say anything but I am glad you decided not to go with the ssd's. Just don't hold up over time from what I have been told. ;)
I figured a faster SATA drive would be just as quick and I don't need much storage (500 gigs is plenty for me)
I have an old out of date laptop with an 80 gig drive. It never got close to being full. The most important stuff I put on data disks.......
GLAD you decided to build.. Its a better overall option and more satisfying.
Sounds VERY similar: http://www.satelliteguys.us/compute...ne/238235-new-pc-build-specs-test-scores.html
Parts list: Right around $700/$750 tax & shipped
Shipping from TN, USA
LITE-ON Black 4X Blu-ray Reader SATA
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
LOGISYS Computer CS305BK Black Steel ATX Tower Enhanced SOHO Computer Case
785W Power Supply
AMD Phenom II X6 1055T Thuban Socket AM3 125W Six-Core Desktop Processor
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders
nMEDIAPC ZE-C68 All-in-one Card Reader w/ USB Port
GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
ATI Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Video Card
Rosewill 19.7" Serial ATA III Blue Round Cables w/ Locking Latch Support 6 Gbps transfer rate
G.SKILL Ripjaws 4GB DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Why do you guys pick Thuban over Sandy Bridge?
The 1075T is the about same $$$ as i5-2500 and is 125W vs. 95W.
Motherboard will be ~$25 more but that isn't the deal breaker, is it?
Diogen.
I recently upgraded my PC using same Motherboard as OP, it does charge the i-Pad, even while being used, this did not happen with my old set up.
Dan
Got my new PC up and running. I forgot how long it takes for software install and updates. It only took me about an hour to put the hardware together, but took me several hours to download software, do updates, and transfer files from my old hard drive
The nice thins is the USB 2 and USB 3 drives which all put out 10+ Watts of power. I cannot believe how fast apps are transferred between my iPad and computer and the extra power allows my iPad to be charged while it is syncing
