Noticed today my guide popup was enabled on my 722k/wMT2/L682.I had it set to guide button selection,never tried the popup.After trying it for awhile it is faster to use the guide popup.Thanks Dish Network!
			WOW! This thread got over 2000 views in just 24 hours! Cool(Sorry. I got nothing else to talk about at the moment.)
What's a "guide popup?"
Tell us about your problem?.![]()
I don't think so. I think the DEFAULT will now be 20, but as always you can change it.
No, HD only is an option on recording. All HD is a guide option and only show HD channels. All Sub and All Chan show both SD and HD. There is no option for SD only nor for HD and SD if no HD.I was wondering the same thing. If both SD and HD channels are available will the HD Only option exclude the SD channels in this case but continue to show SD channels if no HD exists? That's ideally the way I'd like to see the guild if there's some combination of options to make it work this way.
Still no option for forcing a manual recording onto a specific tuner when in dual mode. I know there are workarounds, but why can't it just be a simple selection from the menu...
The "page" buttons can also affect the aspect display. Try playing around with them.My 722 is also running single mode connected via hdmi to a Panny plasma. One of the tuners exhibit the same non-functioning * format button as well. The HD channels are stuck in normal (which is at least viewable) and SD in some stretch/zoom display.
Yup. Every time I order or select a program that is 1080p, I get a screen that tells me that the resolution of my DLP is being checked to see if it is 1080p capable, then proceeds after a couple of seconds. WHICH I find redundant and unnecessary since in the HDMI Test area (Menu-6-3-Analysis ^ HDMI Test ^ Info 2) it already knows that it can and says that the receiver can see my DLP and that it is capable of:. . . Can people who have actually seen this post please? . . .
You sure about that? It definitely works on my 612, and I thought it worked on my 722...I don't know where you get this idea from but the "page" buttons do NOTHING with the aspect display on any 622/722/722k/922 receiver
There are two issues depending on how you are using the dual tuner dvr. I've got my 622 running in single mode connected via component with 480i output to a 32" Sony crt. When tuning to a 16x9 HD channel (either Dish or OTA) depending on which tuner it is using, the display is scrunched and the * format button has no effect, even though the display will scroll through normal, stretch, partial zoom, zoom and gray bar. If you cycle power on the dvr then the channel will come up on a different tuner and be correct with the * format button functioning. My 722 is also running single mode connected via hdmi to a Panny plasma. One of the tuners exhibit the same non-functioning * format button as well. The HD channels are stuck in normal (which is at least viewable) and SD in some stretch/zoom display.
Like dahenny said, they used to work on my 722, but no longer do. I was looking at my 211 and there Page up cycles through HD Stretch-Partial Zoom- Zoom-Gray Bar-NormalI don't know where you get this idea from but the "page" buttons do NOTHING with the aspect display on any 622/722/722k/922 receiver
