NEW TO THE AREA OF KU/C BAND LNB ON A MINI BUD
batzzz19
165
14
los angeles
IM JUST TESTING TO SEE IF I CAN GET 97W
ON A MINI BUD
MY DISH IS ONLY 33" AND I HAVE A POLAR ONE WITH LNB IN CENTER
I WILL ADAPT TO A SCALAR RING AND NEED HELP ON THE LNB TYPE
I HAVE AN IDEA BUT NOT SURE WICH LNB I SHOULD BUY BECAUSE I WILL NEED IT
IN THE FUTURE THE LNB AND SCALAR RING TO SWITCH TO A 6' DISH TO USE
I WILL ALSO NEED IT TO WORK BOTH ON A MINBUD AND A 6' DISH SEPERATELY OFCOURSE
IM PICKY NOW BECAUSE FOR TWO REASONS I CAN THINK OF:
FIRST I WILL NEED IT TO WORK WITH A CONTROLLER STRAIT TO LNB
BEACUSE I WILL SWITH LATER,
SECOND I DON'T NEED TO WASTE MORE MONEY ANYMORE ON LNBS
OH, AND ALSO, THAT IT WILL WORK ON A MINIBUD FOR NOW WITHOUT A MOTOR
SO AFTER, I WILL USE AN ACTUATOR TO IT WITH A CONTROLLER, LIKE V BOX
I NOTICES THIS
Model
BSC621
BSC621-2
BSC621-2D
Output F connectors
3
3
2
Ku LO Frequency
10750 MHz
9750/10600 MHz
9750/10600 MHz
C LO Frequency
5150 MHz
5150 MHz5150 MHzInternal Switching
22 KHz
DiSEqC
N/A
I WANT SOMETHING THAT HAS INTERNAL SWITCHING
TO C BAND TO KU BAND AND WORKS WITH A CONTROLLER FOR LATER USE
AND THAT I CAN USE ON A MINI BUD FOR NOW
AND ALSO HEAR BSC621-2D IS GOOD WITH MINI BUD ON RECEPTION
BUT I DON'T KNOW SINCE I FOUND OUT IT DOESN'T HAVE SWITCHING OPTIONS
FOR CONTROLLER ON LATER USE
SO IM NOT SURE
PLEASE APPRECIATED
I WILL POST A PIC OF WHAT I DID FOR THIS 33" DISH TOMORROW
I DIDN'T POST THE INFO RIGHT FOR THESE LNBS
IM GUESSING IF IM GOING TO GO WITH MINI BUD AND THEN AFTER A 6' DISH I WOULD NEED A BSC621-2 TO USE ON BOTH
HERE IS WHAT I WAS LOOKING AT
BSC621 BSC621-2 BSC621-2D
22K DISEqC NONE
It looks like an offset dish to me, but you've positioned the lnbf like its a prime focus dish. Assuming that it IS an offset dish, your lnbf is NOT at the focal point. I don't expect you will be very happy with your reception in this configuration.
Me three.
Plus even if the dish were a prime focus (and I've seen some which are), it's not going to have a narrow enough beam width to do much on C-band.
We've been over this all before, and a 1 meter dish will get you just a taste of C-band.
For equipment, I'd suggest a C-only LNBF like the C2 from SatelliteAV, or the DMX242 from Galaxy Marketing see top of any page).
They're quite inexpensive.
That'll work well on any actual mini-bud or six foot dish.
Use your little dish the way it was intended with a Ku LNBF, and you'll be better off.
Oh, and if you would please, do not type in capital letters on the forum.
That implies yelling.
even if the dish were a prime focus, it's not going to have a narrow enough beam width to do much on C-band.
Hi Anole,
Could you give some good links about this issue to refresh my memory, especially regarding beam width affect of an offset dish on C-band reception? Not just reception reports, but some kind of background? :)
Which LNB (Standard or Universal) is required for Nilesat in Toronto?
Coolsat 5k question
